EB wrote:I'm convinced on the MT prop. Then I got on trade-a-plane and found a 1996 Husky with o-360, super clean, ready to fly.
I'm about to go test fly this Husky today. It's thirty thousand more than the 170b, but with the time and process and expense of upgrading to o-360, seems it will be about the same in cost without the wait time for STC and prop kit etc. I like the 170B, but I'm also partial to Husky's.
If anyone has an opinion on 1954 170B which within 3 months would be upgraded to 170 super (everything goes well, that is), or a 1996 Husky A1A that is ready to fly with o-360 now, and very clean looking, I'm listening.
I had a 1954 170b for 10 years. It was a fantastic plane. Light on the controls, great visibility, fuel efficient and super easy to land. I flew it often and learned a lot in that plane.
It had the stock power plant. I fly at high density altitude, and operate from short fields and off airport often, so it didn’t satisfy my mission any longer.
I researched installing an O-360, and it never penciled out. I could not figure out how to do it for less than 35k, and this was ten years ago. I would bet closer to 50 these days. And then... when do you stop improving a 60 something year old airplane? Engine monitors, avionics, paint, interior, STOL mods, etc.... it never ends...
I ended up in a 180, which is very capable, but not quite as fun as the 170. I’m on the fools errand of dumping buckets of cash in to it
Projects ALWAYS take more time and money than expected. Usually by no small amount.
Last year, a few friends and I partnered up in a 1997 Husky A-1A. It is a real hoot to fly! It sips the fuel, and has relatively large tanks for adventuring far and wide. It’s much faster than a Cub in cruise, but won’t land as short. Flying low and slow with the doors opened up is dreamy.
The Husky is a well designed and very low maintenance airframe. I would budget for a set of 31s, and definitely look for one with an MT over the Hartzell, but otherwise a nice Husky should be ready to rally without extensive modifications.
If you don’t need the cabin volume of a four place spam can, and are more interested in a plane to fly rather than a project, I would probably go for the Husky.
