: those thick aluminum flat bars meant to serve for a place to put your feet when you work the rudders, mine are all drilled out/lighter and work just fine. Another place, as an example: the 4130 brake formed standoffs/brackets that serve to support the skylight windshield area, no need to keep them as is, just dead weight. Many more places once you start looking! One more: the gusset at the base of the rudder post. No big deal if you don't bother, but just wanted to throw that option to save a little weight out there.pouellette wrote:That oil tank mounting looks a little low. It should be raised to almost touching the top motor mount. Also, it needs to be rotated a little.
see here:
http://www.flyingfoxservices.com/Flying ... _FSDO.html
Also, I have a lot of pics posted on my build, maybe you will find some useful. They are here:
https://plus.google.com/photos/10288596 ... O2qwuvc9gE
and some later pics here:
https://plus.google.com/photos/10288596 ... 9O28h_WsbQ
Pete
