Thanks Gump for that. We learned before the Practical Test Standard came into being in the 70s. The PTS is, because of complete dependence on numbers from gauges, a basic instrument standard. There should be a contact test, like our instructors saw that we would be prepared for, and an instrument test that we got later. The two just don't mix well. Integrated contact and instrument became popular in the 70s as well.
Instructors have been intimidated into thinking the PTS is regulatory. It is a test standard, not a set of regulations. Instructors have been intimidated, by the PTS and the definition of maneuvering flight, into no longer teaching NOE flight, as our instructors taught us. In those old airplanes, in the mountains, all flight was NOE. There was insufficient power to be anywhere else.
You are correct that scud running is an art, not a science. The techniques that will keep us alive are not describable in terms of numbers on gauges. It is not all airspeed and altitude. We are low and we may need to slow down, by energy management or throttle change or flaps or a combination, to reduce our radius of turn. And we need to always know where the wind is from and which way is down hill. We need make use of both wind management and gravity thrust of altitude and thermals and ridge lift and ground effect. Too few pilots understand that being on top of a hill at 10' AGL is fine, if we are willing to fly down hill.
We are old and will be out of here before it goes all drone. I have taught a lot of kids and a lot are learning on their own. There will always be good pilots, but it is getting harder for them to learn without losing their paper.
