Ya it can be done but only until it can't. So back to ICE landing. Tires work fine on ice and are sometimes even better than skis however, not all ice is the same. Black ice that you see on runways with fresh rain/recent melt quick freeze sucks now matter what you have on the plane. Takeoff is usually quick and easy but little to no stoping control with tires, you can wag the tail and use the skeg on skis to help slow the plane but leave a lot of room. Properly set up ski brakes do work good on ice really don't help in snow. Rough ice and hard pack snow that will will find at most lake runways do just fine with tires and skis. Breaking is just like with a car it depends on the Ice. Another problem we have is pilots will try to land on the ski strips in the spring with Bushwheels. It works if the snow is not deep but they leave big ruts and when they freeze at night really screw up and make nice ski strips dangerous. It only take a few hours to swap skis to tires to straight skis, you can do it yourself once trained, set up a system to do it and enjoy both over the winter. MRebel wrote:I've landed on bare ice on both wheels and skis. I found that wheels do provide a little bit more traction and braking then skis. I had 8.50 tundra tires at the time. As for ground loops on wheels, I think its actually safer on bare ice. If you loose directional control and drift sideways, your tires have no grip and can't grab and flip the aircraft onto the wing. You just slide along sideways... or backwards if your really showing off.
The skis I have have UHMW bottoms and are as smooth as possible to reduce drag on takeoff. I don't like to land on bare ice with skis as it puts the entire weight of the aircraft on very small area of the ski with no cushioning.
I also slid from one end of the lake to the other, the only thing that stopped me was a skiff snow near shore. I realized after that I should have shut the engine down and I would have come to a stop sooner. When I tried to taxi I could not point downwind, every time I'd rev the prop up and throw all the rudder in I could, it would only go halfway around or all the way around. I even have a steerable tail ski. I'm sure it looked comical. I learned a lot that day.
