The POH for my 1958 C-180A doesn't have a speed for Best Glide. There is sort of a Vx- 60 mph and sort of a Vy- 90 MPH. I've heard folks say that Vbg is between the two. That's just a shot in the dark. To me its kinda important to know what speed is best to fly.
At any rate a POH number would refer to a stock wing. My wing has a Sportsman Cuff, the WingX STOl extensions and MA Vgs. Plus you add the drag of those Desser 31's and you have a whole different kettle of fish. I've been wondering what would be the best way to figure all this out so I noodled with Aerodynamics for Naval Aviators and some stuff on the interweb. There is a way to do this by figuring out what the V endurance is, from that you can compute Vrange. My assertion is that AOA is AOA and Min Sink is equivalent to Vendurance.
I ran the test and my numbers were little different than the Sportsman numbers offered in another BCP thread. Probably due to my drag profile. But there were no tests done for Flaps 10. My intention was to do the test with 0,10,20,30 and 40 flap. In the end I only did a full test at 0, and 10 flap. At flaps 20-40 I ran into the stall and any descent rates were well above those achieved at 0 and 10 flap. Since I was interested in only finding min sink I stopped the test. After all, I'm not validating the STCs, just what my airplane does.
The bottom line is that the best Vms I found was at flaps 10 and 43MPH (fr a 290 fpm descent rate) and a Glide Ratio of 13.1:1. Best Glide, Vbg, was at Flaps 10 and 57 MPH (590 FPM) for a Glide Ratio of 14.8:1.
Not too bad for those big tires and struts and all that. It's a test that everyone can try out for your own airplane, the way you usually fly it. Figure out your Min Sink Speed and then multiply it by 1.316 for your Best Glide Speed.
Check out the video.
gunny
