Backcountry Pilot • sleeping cots
sleeping cots
24 postsPage 2 of 21, 2
Re: sleeping cots
I have a pair of Roll-A-Cots which I've used for several years. They weigh 10 lbs. each for the standard size; they have a wider version (same weight) and a wider/longer version (13 lbs.). The tension of the sleeping surface is adjustable. With a Thermarest mattress on top, they are easily as comfortable as our Select Comfort bed at home. They sit high enough to comfortably sit on. $130 on Amazon. Their website is pretty descriptive: http://www.camptime.com/roll-a-cot.htm
With the Thermarest insulating me, I don't think it's any colder than if I were on the ground, at least not enough to complain about. I guess the coldest I've slept on them is about freezing at Marble a couple of nights. It is nice to be able to store stuff under them, and to have someplace to sit in the tent besides the floor.
You'll see a lot of favorable comments about these cots, and I've sure been pleased.
Re: sleeping cots
I've alway worried that cots would wear holes in the bottom of the tent.
Does this happen?
Bagarre offline
Re: sleeping cots
Bagarre wrote:I've alway worried that cots would wear holes in the bottom of the tent.
Does this happen?
I have not noticed any tendency for that to happen with the Roll-a-cots.
Re: sleeping cots
Does this happen?
I was on my iPhone when I posted--hard to elaborate typing 1 finger at a time! (Some would appreciate it if that's what I always did, right?)
I was concerned about that possibility, too. As do most campers, I have a "footprint" under my tent, but often the ground is relatively soft, such as when it has a good grass cover. So when I first got my Roll-a-cots, I wondered if I should put some sort of saucer under each leg to protect the tent floor. When I packed, though, I didn't think about that again until I was setting up camp at OSH. It had rained earlier in the day, and the grass was wet. As my friend and I put our cots together, that's when I thought about it again. I looked at the tent floor pretty carefully the next morning, and I couldn't see any indication of stretching or puncturing.
That was about 6 years ago. Since then, I've camped many times, on several different surfaces, and there still are no indications of any stretching or puncturing. I suppose it could happen to an extra cheapo tent, but the material of my Big Agnes doesn't seem to be affected at all.
