Our 1955 C180 has a lot of slop with the yoke rotating relative to the control tube. It's bolted on with two AN3 bolts which measure 0.20" on my crappy caliper (spec says 0.189) whereas the holes measure 0.21" giving 0.010" of play. It is very annoying. There are supposed to be rivets, 0413216 and -4, but I can't find the diameters of those rivets. Does anyone know if they are fatter than an AN3 and will eliminate the slop?
Thanks!
Thanks Richard. This was very helpful. I will keep a couple of those fasteners in stock so I can fix them!richpiney wrote:Our 1955 C180 has a lot of slop with the yoke rotating relative to the control tube. It's bolted on with two AN3 bolts which measure 0.20" on my crappy caliper (spec says 0.189) whereas the holes measure 0.21" giving 0.010" of play. It is very annoying. There are supposed to be rivets, 0413216 and -4, but I can't find the diameters of those rivets. Does anyone know if they are fatter than an AN3 and will eliminate the slop?
Thanks!
I was trying to give an answer to the original posters question. I replaced my plastic yokes with the aluminum ones, which I had powder coated black as viewed in the pictures I posted. In order to do this, you have to drill out the original steel rivets. If you just simply bolt the replacements on, as in the situation which he described, and use stock AN3 bolts, those bolts diameters are too small for the original hole. This will create even more slop, with the eventual relative movement which at some point is bound to occur. It was described as "very annoying" I thought I found a solution that addressed this and wanted to share it with others and perhaps save some trouble in the future, such as what the original poster noted.
Richard
richpiney wrote:The original solid steel rivets, (the upset end is hollowed) are .215. A number 3 drill bit at .213 fits in with slight clearance. If I were me, I would install an HL220-6-X Hi-Lock Pin. (I have not determined the length yet, (perfect fit no slop) and an MS 21042L3 nut.
Far stronger than the bolt, easily removable, and actually fits the hole as opposed to a bolt.
richpiney online
Here is what I was talking about. Zero slop as opposed to an AN Bolt. Tap in with a rubber mallet.
I ended up using an AN21045-3 nut.
[img]https://backcountrypilot.org/images/originalphotos/2430/5840/7fd20df943227e14522237bc.jpg[/img
Just an idea...
Tex wrote:The rivets Cessna used and discribed above, how would I order them?
BazzLow wrote: What about removing the pax side yoke all together? I assume that would be a major alteration and need to submit a 337 to the FSDO. It'd be convenient to be able to remove and reinstall on occasion.
BazzLow wrote:What about removing the pax side yoke all together?
