Thanks!
Ace007 wrote:... It's bolted on with two AN3 bolts which measure 0.20" on my crappy caliper (spec says 0.189) whereas the holes measure 0.21" giving 0.010" of play.....
hotrod180 wrote:Ace007 wrote:... It's bolted on with two AN3 bolts which measure 0.20" on my crappy caliper (spec says 0.189) whereas the holes measure 0.21" giving 0.010" of play.....
Are you sure the slop is all in the bolt?
Those universal joints often loosen up over time.
They're not cheap either.
Ace007 wrote:....Dude, read the original post.
lesuther wrote:then the OP sets the bar pretty low. Possibly too low for anything readily certifiable. So I guess the OP is asking about a kludge regardless of certification status of the repair.
The original solid steel rivets, (the upset end is hollowed) are .215. A number 3 drill bit at .213 fits in with slight clearance. If I were me, I would install an HL220-6-X Hi-Lock Pin. (I have not determined the length yet, (perfect fit no slop) and an MS 21042L3 nut.
Far stronger than the bolt, easily removable, and actually fits the hole as opposed to a bolt.
richpiney online
How do you tighten that up with out the bolt spinning?
