Backcountry Pilot • Steve's Gascolator
Steve's Gascolator
31 postsPage 2 of 21, 2
Re: Steve's Gascolator
Steve, any progress on the 180hp Husky approvals?
I need to order one today. I noticed mine on the Left side has started seeping around the bowl. Forgot to take a picure of it to make sue I get the correct fitting for my incoming lines
sierrasplitter offline
Aircraft: 56 PA 22/20
What's the advantage of ditching the remote cable system?
CParker offline
Aircraft: 1979 TU206G
G44 wrote:Steve, any progress on the 180hp Husky approvals?
Still working on it... Unfortunately since COVID the FAA has pretty much shelved everything when it come to getting updated approvals.. :roll:
CParker wrote:What's the advantage of ditching the remote cable system?
Less chance of the cable "sticking" and draining all your fuel out of the bowl. But, for those that want to keep it I do have a remote drain bowl option.. It is 4oz and works well with Cessna's..
Brian
Brian-StevesAircraft offline
Pavement scares me..........
Dad's SPOT page
Without the cable, are you reaching up through the cowl flap and draining the bowl then? Sorry, unfamiliar.
I'm a little worried about my strainer drain, I have to pull pretty hard/far ton the knob to get any flow, to the point where I think the aluminum where the pull is mounted is starting to give a little from years of yanking.
CParker offline
CParker wrote:Without the cable, are you reaching up through the cowl flap and draining the bowl then? Sorry, unfamiliar.
Yes you just reach up and use the same sump checker that you use for your tanks. Not really much of a reasch as the bottom of the drain is right there.
Another advantage is the ease of servicing these compared to removing the old stand pipes on the original one. Steves are awesome.
It appears all Husky models are now on the list.
Edit: well maybe not the C 180.
Flying Dave offline
Aircraft: Aviat Husky
Still working on it.. Its FAA and Covid.. They work from home and are slower than slow.. :roll: \
I have at least 6 or so models to add.
Brian
Dad's SPOT page
Brian
Thanks Brian! I will order one from you in a couple of months for my Husky A1-C
Sorry, duplicate post.
I ditched my cable pull on the strainer drain on my Steve’s. The sump is actually right next to my cowl flap but is easily accessible. It is nice to be able to see the fuel that is sumped as well, just another confirmation there isn’t water and debris blocking the system. Steve’s are way cheaper to service as well, Cessna strainer parts are ridiculously expensive.
185er offline
Aircraft: Cessna 185
