Rob,
I guess I wasn't very clear on my thoughts on the L-19 either. The L-19 is basically a 170 with a big engine and a somewhat different fuselage. They offer great visibility, and their performance is great, no doubt.
The down side is that like the 170, they are all pretty old, and there aren't nearly as many of them around as there are 170's. So parts can be an issue. Right now, they are being supported, but all it takes for that to change is for one company to go out of business. Frankly, that's true of a number of planes, though.
The original engines are sort of an odd duck. They work fine, but are hard to get overhauled, and to switch engines to a "better" engine means approvals, etc, and more money.
The Sia with the Allison turbine is a performer no doubt.
I think my comments regarding the L-19 weren't so much that it is a bad airplane, but rather that for the money, there are other airplanes that would be easier and less costly to support. It may not have come across that way, and if not my apologies.
Idaho, there are TWO very different VG kits for Super Cubs. I've flown the same airplane before and after with both kits. They both help, but they also do somewhat different things for the airplane.
One of the things I failed to mention earlier is that I know of one Sportsman kit that was installed at the wrong angle
. That owner was rather displeased with the kit, but it wasnt' the kit's fault.
Again, different airplanes, different uses for the airplane, different pilots will all produce very different opinions of all these things.
More wing area WILL increase lift, assuming the same speed and AOA--a pretty incontrovertable fact. The rest, well.....
