Whose mod is that?
Idaho Supercub
shortfielder wrote:There is no substitute for experience. But I do feel that some of these mods do make things easier and help reduce the stress on the plane on the off asphalt strips.
a64pilot wrote:Down low, 2000 DA on my 83 Maule M-6-235, I went from a full throttle speed of 158 mph indicated to 150 mph indicated with Microaerodynamics VG's. At cruise power it was about 5 mph loss down low. My best altitude for speed used to be between 7 to 9 thousand ft PA where I got 132 kts true. Now my best altitude is between 9 to 11 thousand PA where I will still get 132 kts true. Not sure of why, but I am sure of my results. Stall speed with flaps retracted dropped a couple of mph, flaps down the same. The critical angle of attack definately changed though, because to keep the stall warning 5 mph before stall, I had to bend it down significantly.
VG's on my Maule are not a STOL device, I cannot fly slower now than before, but I do have more elevator authority and aileron authority than without.
flyer wrote:a64
If your stall warning AOA changed significantly, the IAS should have changed proportionatley. I would think that IAS would be somewhat inaccurate at these high AOAs. The pitot tube is way out of line with the relative wind. Once again I am confused.
Knowing what you now know, would you put the VGs on your Maule?
flyer
a64pilot wrote:There is no free lunch. A theory is that by delaying this seperation you basically create a laminar flow wing
