Sent from my SM-G920W8 using Tapatalk
VortexAlternator wrote:Since we are both working on experimental super Stinsons, we have the higher engine weight W+B issue. Im sure you would like to avoid ballast as much as me. Would adding a ~3” leading edge cuff not move the MAC forward enough to compensate for the higher nose weight? l’m thinking of making a replacement rib or leading edge fuel tanks with a droop built in. thoughts?
