mmartin1872 wrote:It is "amateur built". So the same category as the bearhawk and rvs etc.
A1Skinner wrote:mmartin1872 wrote:It is "amateur built". So the same category as the bearhawk and rvs etc.
Lucky. I've been wanting to get a 180 fuselage over. Not as easy as it once was...
hotrod180 wrote:A1Skinner wrote:mmartin1872 wrote:It is "amateur built". So the same category as the bearhawk and rvs etc.
Although it has been done (witness Greg Miller's Bushwhacker, for one), I understand it's a pretty tough show to get a certificated aircraft re-registered as an amateur-built experimental in the US nowadays.
I would like to know more about putting an airplane into the "owner maintenance" category in Canada. What do you have do to make it happen, and what are you allowed / not allowed to do to the aircraft afterward?
mmartin1872 wrote:I'm hoping not to need 6 lbs.. We're building the airplane with the battery all the way back there, and we are going to put the permanent survival kit back there . Elt etc. Hopefully lighten the nose up with a light starter and alternator.
