Bravo Hotel wrote:My dad used to own the yellow turbine Maule above on Wips. N420WP. I have about 200 hours in it on floats. I can tell you the useful load on that plane on Wipline 3000's is around 460 lbs. In my opinion, it is one of the worst back country planes a guy can have. Here is why. The fuel cap on it require a special rubber nozzle that most local FBO's do not carry. You would need to neck down the size of the filler nozzle in order to pump into the wings. Most FBO's jet A systems are designed for big planes. The second problem was range. I cannot remember off the top of my head, but it would burn way to much fuel. Combine the lack of convenient fuel nozzles around, the oily greasy smell of JetA, and the high burn rate, and you have a really annoying situation. I wanted to bring it too Wipaire in Minneapolis and have Chuck design a single point attachment but that would have been a field approval that my dad did not want to mess with. Insurance was around $10,000/ year on floats. The other problem was the 90" prop in reduced power settings. If you have ever flown a turbine, you know how sensitive they are lose to the ground with the throttle near flight idol. I bounced my first few landings trying to figure out the sweet spot on landing. If you tried any of the tire dragging in the water stuff you would be wet real fast because of the lag in response and spool up. If you want a Maule, buy the 260C. If you want a turbine and have unlimited amounts of $$, buy the Turbo Beaver. BTW the yellow and white one above was sold for $370,000 in 2008 I believe. You could do 3,000 FPM decents all day long with it.
Morning BH. Don't want to waste your time so only answer if it convenient. Do you remember the FPM Climb on wheels? How did your dad end up buying the Maule with so many known issues. He must be like my dad was. He just wanted it so he bought it. ha ha
I still think 420 HP in a M7 would be nuts, in a good way. I would just buy my own rubber adapter and keep it in the plane.
Cheers..Rob
