Mapleflt wrote:Do you recall any performance numbers, cruise speeds, range etc
Lisas7ECA wrote:Martin's 11CC has enjoyed a unique journey. Like the woodsman's axe, right now it's on its seventh handle and its fourth head. These numbers while offered freely here for comparative purposes are perfectly accurate for his individual aircraft alone.
Lycoming O-235, no flaps, 115 HP, 80/87 minimum (Mogas STC),
Normal Ranges unless noted (speed in MPH)
RPM 1800-2800
CHT 90-150
OT 100-245
OP (warning 25-60) 60-100
Vne 162 (153 with certain struts, see Service Letter C-127)
Yellow Arc 162 (153)-120
Vno 120
Va 120 (at gross)
Green Arc 120-50
Vs 44
14.2 aft to 19.2 aft of LE at gross weight
10.5 aft to 19.2 aft of LE at empty weight
straight line variance
Empty weight land 840 (on straight Zen 1450s 920)
Gross weight land 1325 (on straight Zen 1450s 1305)
Useful load land 485 (on straight Zen 1450s 385)
NOTE: The 235 and Zens were FAs. My read of the regs is that an A&P, arguably the owner, can put Edo 1400s on an 11CC making it a S11CC, which has a GW of 1400 lb. There is a STC for the Edos that lists a increase in empty weight of 100 lb from wheels, and increases gross weight 175 pounds, The Zens ONLY increase empty weight 80 pounds, decreasing usable load by that amount, to 485 lb. Empty weight, Gross, Useful load with Edo 1400s would be 959, 1400, 441 without the STC and 940, 1500, 560 with it.
