Backcountry Pilot • SVFR departures/arrivals
36 postsPage 1 of 21, 2
With the implementation of AWOS, airspace maybe reporting IFR but, in reality it’s perfectly safe to depart/arrive VFR in a helicopter or small fixed wing. Specially, on the West coast when the marine layer shrouds portions of the airport while other portions are completely VFR in departure/arrival routes. Instead of waiting for the entire airport to become VFR, requesting a Special VFR clearance would seem acceptable.
My ship is not certified IFR (nor can be). So SVFR is definitely an option under safe conditions.
Has/does anyone requested Day SVFR in similar conditions?
https://www.law.cornell.edu/cfr/text/14/91.157
§ 91.157 Special VFR weather minimums.
(a) Except as provided in appendix D, section 3, of this part, special VFR operations may be conducted under the weather minimums and requirements of this section, instead of those contained in § 91.155, below 10,000 feet MSL within the airspace contained by the upward extension of the lateral boundaries of the controlled airspace designated to the surface for an airport.
(b) Special VFR operations may only be conducted -
(1) With an ATC clearance;
(2) Clear of clouds;
(3) Except for helicopters, when flight visibility is at least 1 statute mile; and
(4) Except for helicopters, between sunrise and sunset (or in Alaska, when the sun is 6 degrees or more below the horizon) unless -
(i) The person being granted the ATC clearance meets the applicable requirements for instrument flight under part 61 of this chapter; and
(ii) The aircraft is equipped as required in § 91.205(d).
(c) No person may take off or land an aircraft (other than a helicopter) under special VFR -
(1) Unless ground visibility is at least 1 statute mile; or
(2) If ground visibility is not reported, unless flight visibility is at least 1 statute mile. For the purposes of this paragraph, the term flight visibility includes the visibility from the cockpit of an aircraft in takeoff position if:
(i) The flight is conducted under this part 91; and
(ii) The airport at which the aircraft is located is a satellite airport that does not have weather reporting capabilities.
(d) The determination of visibility by a pilot in accordance with paragraph (c)(2) of this section is not an official weather report or an official ground visibility report.
[Amdt. 91-235, 58 FR 51968, Oct. 5, 1993, as amended by Amdt. 91-247, 60 FR 66874, Dec. 27, 1995; Amdt. 91-262, 65 FR 16116, Mar. 24, 2000]
Note: I know of at least (2) pilots that were reported by a USCG helo because they were below minimums VFR within Class E. C310, Bell 47
Re: SVFR departures/arrivals
I have received SVFR clearances in such conditions quite a few times, legal, safe and acceptable.
alaskaoe offline
Aircraft: PA-12
alaskaoe wrote:I have received SVFR clearances in such conditions quite a few times, legal, safe and acceptable.
Thank you. I have mostly flown out of Class “B” (IFR/VFR). Just wanted to confirm if I was on the right sheet of music requesting SVFR at small airports. Will definitely consider the option out in “Nowhere’s Land”. You never know who’s watching these day!
I made an exploratory call to Seattle Center on the telephone today and they said talk with FSS first (RCO) and if they can’t hear/help give Center a call. The controllers around PNW are very easy to work with in my opinion.
Yeah, I get SVFR when it’s safe and I need to operate.
I got caught in some smoke in Fairbanks a few years ago and it was the only way back into Chena Marina. Had to orbit outside the D until they landed some commercial traffic though.
8GCBC wrote: Just wanted to confirm if I was on the right sheet of music requesting SVFR at small airports. Will definitely consider the option out in “Nowhere’s Land”. You never know who’s watching these day!
Just remember. Except at airports with certified weather stations/observers, current conditions are not determined by someone on the ground.
Sent from my E6910 using Tapatalk
S2D offline
CamTom12 wrote:Yeah, I get SVFR when it’s safe and I need to operate.
I got caught in some smoke in Fairbanks a few years ago and it was the only way back into Chen’s Marina. Had to orbit outside the D until they landed some commercial traffic though.
Very good. Was that during your trip to the lower 48?
Yes “in flight visibility” gives a Pilot a little more clout if there is an issue. My home “plate” (helicopter term) has AWOS, USCG helo, LifeFlight helo and nosying neighbors. And the “dime” was dropped to the FAA on several occasions which precipitated monetary fines!
I’m really paranoid of getting below VFR in controlled airspace! It’s easy where I fly because of the fast moving weather and the chopper is going slow and low.
No mysteries regarding SVFR. First thing: ATC cannot offer or suggest SVFR, pilot must request, and be familiar with the requirements.
I prefer to call the controlling agency rather than Flight Service....Flight Service just has to call the ATC anyway, so may as we’ll talk to the person with the power.
In parts of Alaska, SVFR is almost a way of life, and no big deal.
Just make sure you can maintain SVFR conditions.
mtv wrote:No mysteries regarding SVFR. First thing: ATC cannot offer or suggest SVFR, pilot must request, and be familiar with the requirements.
Thank you for input...
Good point about receiving a truncated clearance from ATC of any type quickly.
Calling ATC would seem logical. I definitely agree. Not sure why the guy I called at Seattle Center’s telephone line suggested FSS on 122.5. Maybe, because the FSS RCO is the only communications in my area at airport altitude? Contacting center requires reaching about 500’+ I believe. I need to try it and see!
Order of hierarchy:
1) Radio ATC
2) Radio FSS (RCO usually)
3) Use cellular telephone
4) Use satellite telephone
5) Turn off transponder, tape over aircraft N numbers and stay quiet on the radio =D> (not recommended)
I requested it once and departed in low vis. Smoke.
I was fine but it was a learning experience and I don’t think I would do it again. Ymmv.
I guess what I am trying to articulate is that I did not know what I did not know. I should have stayed on the ground.
Interesting you mentioned how an SVFR clearance from ATC might be a “siren song“. When I flew my amphibious airplane in BC and Alaska, I literally could NOT believe how fast the weather changes and the disparity in weather forecasting. The risk, I observed, other Alaska pilots were taking was insane! A big wakeup call for me (a surfer dude from Hawaii)! I thought to myself there’s going to be bent metal...
Now mix in a table spoon of Part 135 trying to make a little money and bang! Everywhere I went there seemed to be accidents related to weather. BC mountains and fiords on the coastal ocean have notoriously fast weather changes. Made a deal with myself flying, in BC & AK stay well above MVFR!!! To leave on a cross country let’s say Bella Bella to Terrace in BC with marginal weather forecasted (not to mention IFR weather) is in my opinion crazy!
Now, marine layers down around California are very predictable. Scary but, predictable. If there isn’t an onshore wind the shore just gets hotter and hotter repelling the fog (yes there are always exceptions). The coast of Canada is much more complex with weather forecasting! Be super careful flying SVFR up there!
I’m glad your personal minimums are higher than required by regulators. Up there mine are too!
SVFR in controlled airspace and marginal VFR in uncontrolled are safe enough given ones willingness to turn back or land should visibility deteriorate. 400' and five miles is much, much safer than 1,000 and one mile. Visibility at 1,000' is almost always worse than visibility much lower.
RON in uncontrolled airspace makes good sense on pipeline patrol or where there is pressure to make food and motel at stops, and to complete a loop in a week. In controlled airspace there could be self applied pressure to make it out. Going back is fine and landing is better than crashing.
I agree weather and terrain constriction is very dangerous in BC. Pipeline patrol there would be a challenge. Do they have the same 20 days flown or shut down that the Department of Transportation imposes here?
contactflying wrote:SVFR in controlled airspace and marginal VFR in uncontrolled are safe enough given ones willingness to turn back or land should visibility deteriorate. 400' and five miles is much, much safer than 1,000 and one mile. Visibility at 1,000' is almost always worse than visibility much lower.
The issue I was concerned about in my amphibious aircraft (which flys half tanks max due to GW) is that you can’t turn around past a certain point! Especially, with the scarcity of 100LL in BC. MVFR in BC on long cross country flights is not recommended in my book. Unless you have a high performance IFR current ship and pilot.
8GCBC wrote:With the implementation of AWOS, airspace maybe reporting IFR but, in reality it’s perfectly safe to depart/arrive VFR in a helicopter or small fixed wing. ................
I think the fly in the ointment in your scenario is whatever viz the AWOS may be reporting.
My understanding is that it the official viz.....no matter what you can or can't see from your aircraft.
One of the pilots at my airport, who often comes & goes in MVFR conditions,
was against the installation of an AWOS here for this reason.
If he lands in legal conditions for a class G airport (daytime- one mile viz, clear of clouds),
he can still be violated if the gizmo is reporting less than that 1 mile viz.
Remember that an AWOS reports what it sees, and where it's looking may be different from somewhere else on the airport.
I even heard an AWOS reporting zero/zero once when it was clear & a million--
dunno if someone draped their dewy airplane cover over it to dry or just what.
8GCBC, I see your point about the point of no return.
Filing and flying IFR is safer, when possible. I never understood the instrument rating requirement for pipeline patrol contracts. Encountering marginal weather is not the place to initiate, from low altitude, an IMC climb to file IFR. I encountered going back down the pipeline low or landing.
Yes. AWOS can throw a wrench into the VFR scenario.
...or...
It could save a life. I love being able to see weather on my ADSB (in) and LTE network ahead without calling FSS or ATC. Several times I have diverted on long flights because I observed a METAR that was changing for the worse.
Everyday and every flight is different to some extent! Stay on your toes and relish SA (Situational Awareness).
95% of AWOS is accurate which isn’t too bad.
Yes, 95% of AWOS is accurate for the area it covers.......which is about a 30 inch diameter.
There’s a reason Alaska pilots really like weather cameras. Trust but verify.
mtv wrote:Yes, 95% of AWOS is accurate for the area it covers.......which is about a 30 inch diameter.
Totally agree with you Mike. My experience is trust no one, not even myself (double check everything). Verify....
PIREPs, Wx Cams, AWOS, NWS, FSDO, NOAA, ATC, internet forums and morning conversations with local pilots in the FBO are all used with cautions.
Note: Not a scientific observation but, our AWOS seems to report lower not higher than actual when in error. just my opinion.
The first AWOS install by the FAA was in Fort Yukon, AK, back in 1988ish.
First winter, FYU went down with -40 and indefinite ceiling and 1/8 mile in freezing fog.
I needed to go to the Upper Yukon Valley, and do some work, and would need fuel. So the weather was a no go. Same for 135 guys....not legal to launch if destination is below basic VFR.
This went on for several days....low ceiling and vis.
Finally, I needed to get some work done, so I figured I’d head north and peek over the White Mtns to see what the Valley actually looked like. Not operating 135, so look see is legal.
Came over the rocks and looked out onto a totally clear valley.....with FYU clearly in sight, 60 miles away. I got some work done, then went to the Fort for gas. As I taxied in to the ramp, I noticed a cloud of fog right at the AWOS. The expediters van was parked beside the AWOS, and running to stay warm......creating ice fog around the machine from exhaust.
I called FSS and told them the situation and turn the AWOS off, and gave a pirep.
Trust but verify....
mtv wrote:Trust but verify....
x2. Great story!
Yeah Ted, that was my first attempt at my flight South. Didn't look so bad in the Fairbanks area but got progressively worse. By the time I got near Salcha I was ready to be back in Fairbanks on the ground so I turned around and got an SVFR back into the Class D to land.
