8" 10" Baby Bushwheel and 14"
wingnut185 wrote:fiftynineSC wrote:good looking plane, that's one of my favorite year color schemes.
How did you like the 10"?
The 10" is my favorite all around tailwheel for the Skywagon. Taller with a bit more flotation. Not a very expensive upgrade if you reuse your wheel and buy just the fork and a tire. Never had a shimmy with the 10". I did not notice any additional steering effort over the 8".
wingnut185 wrote: I use the tailwheel lock on every pavement landing with the 14". ANY xwind or quick correction will cause the 14" to shimmy on pavement. The 14" must be set down straight or it will shimmy on pavement. Yes, i have the AKBW extra arch tail spring. I really like the 14", but I can't recommend it without a lock. Once I figured out how to properly set the bering preload, the 14" requires just a bit more steering effort than a 8" or 10" on pavement. In the soft and rough stuff it takes much less power and effort to move the tail around.
