M6RV6 wrote:Here is a place that can supply just about any kind of ball ya need!!
http://www.plasticballs.com/
If someone wanted to give me the ID and the OD of the bushings and what they wanted it made out of I have a friendwho would machine some for you. PM me
BirdyinBOI wrote:My control yoke (the rods) are very loose in the bushings. I haven’t pulled the panel apart yet but is it possible the collar holding the balls is loose, thereby causing the “slop” in the tube? If not then what is the best option for replacing the balls...a few years after this thread stopped...maybe a fresh source out there. Thanks!
BirdyinBOI wrote:Mine is actually 0411224. Triangular base with the ball inside. All the pics are from the front. I wonder what the back looks like and if the ball is easily removed? I guess it looks the same. Just 2 halves mating together.
akgreg wrote:Having your balls get overtightened is very dangerous! Proceed with caution
c170pete wrote:mcmaster.com part number 9164K39
1 1/2 inch white delrin ball, $3.58 each.
Couple of those and some beer for your favorite machinist do drill a couple holes...
That's the way I would do it.
I went this route and drilled them out myself with a drill press. Owner produced part. It worked out really well. Should last another 69 years.
