Backcountry Pilot • The Champ
The Champ
12 postsPage 1 of 1
The Champ
Does anyone in the BCP community know off the top of their head if any of the Aeronca Champ engine STC's also allow for a gross weight increase ?
Re: The Champ
I don't think so, at least for the 7AC. I could be wrong, but I have looked briefly mainly out of curiosity. If there is I do think I would be more compfortable with a metal spar upgrade.
Pete
pburns offline
Aircraft: Champ 7AC
Re: The Champ
There are literally dozens of different designations for the various Champs. And some allow conversion from one designation to another. These are just under Champ TC, I believe.
I’d start by talking to the folks at American Champion, and look for a Champ group on line.
But, I seem to recall at least one of these mods which actually changed the designation to another model, and I think increased GW. But, that mod also required airframe alterations.
Good luck on the research.
Re: The Champ
The Champ I had with the Buzz Wagner conversion was raised to 1300. Was an O-235 .
Re: The Champ
Pretty certain long stroke oleos increase GW 50 lbs.
flyingjack offline
Aircraft: Husky/T206H
Re: The Champ
flyingjack wrote:Pretty certain long stroke oleos increase GW 50 lbs.
If that's the "no-bounce gear", I've heard that bumps up the gross-- right out of the LSA envelope.
Re: The Champ
WWhunter wrote:The Champ I had with the Buzz Wagner conversion was raised to 1300. Was an O-235 .
Did that increase useful load, or did the weight differnce in the engine cancle it out?
Pete
pburns offline
Aircraft: Champ 7AC
Re: The Champ
Empty weight was 891 if I remember correctly. So UL of 409.
Re: The Champ
Hotrod180- you are correct.
flyingjack offline
Re: The Champ
There are some engine conversions accomplished through STC (like Buzz Wagner) and there are some conversions that utilized a change in the type certificate designation.
As an example, a 7AC might be upgraded to a C-85 and use a type certificate change to become a 7BCM which is the civilian designation of the military L-16A that came originally equipped with the C-85. The L-16A also came with “no bounce gear”, a brace between steel tubes near the lower portion of the boot cowl, and the lack of a larger dorsal fin that is typical of most C-85 conversions. The original L-16A military manuals specified a gross weight of 1,350 pounds but that is not what the FAA allowed when converting it to civilian designation (at least not the one I flew who’s paperwork showed 1,220 lbs as the gross).
By contrast I instructed in a 7AC with a C-85 with a large dorsal fin, standard gear, and it had a gross weight of 1,300 lbs.
Unfortunately the devil is in the details of how it was converted to C-85 power which makes the topic as clear as mud.
If you find a definitive breakdown of the STCs, type certificates, engines , and gross weights somewhere, please share as it really would be a tremendous resource.
WA_L16 offline
Aircraft: Piper L21
Re: The Champ
Bill Pancake had an up gross for them. He is probably the sharpest guy alive when it comes to Aeroncas, and just loves talking Aeroncas.
I did a Chief with his C85-12 stc. It’s well written and gives lots of leeway.
https://generalaviationnews.com/2018/08 ... go-to-guy/
Amodel offline
Aircraft: Cub
Re: The Champ
+1 Bill Pancake= the best with Aeroncas. Easy to talk to.
flyingjack offline
12 postsPage 1 of 1
