True, A1.
But, I'm pretty sure that there's the "required" amount of clearance for an 82-84" on floats?
Or, dare I hope to get Field Approval from the FAA for an 80" THREE-bladed MT propeller?
Ya, I'm not sure what the clearance requirements are down to floats. Sire would be nice though!BluNosDav wrote:True, A1.
courierguy wrote:I'm currently setting up a 79" LUGA 2 bladed, grd. adj. prop for the Rotax/S7-S combo. That is HUGE, nothing bigger in dia. in the Rotax world! It has curves in all the right places, being a scimitar planform, is all carbon fiber with a stainless leading edge, is super light, and is (no other word for it) sexy as hell. I have an airplane savvy neighbor I will use as my sound dummy, he was the first to tell me my Prince made such a deep tone it almost sounded like it was radial engine powered . I don't expect the LUGA to be obnoxious, but do find the sound a prop makes pretty important
john54724 wrote:I have a digital strain gauge you can borrow any time you want to put a real number on static thrust. To test climb and cruise performance, I can provide you the FAA flight test parameters required when the FAA Test Pilot is gathering data for certification approvals.
hotrod180 wrote:About the closest thing I can think of to your airplane is a Maule M4 or M5-210.
FWIW dunno what might be STC'd but the Maule TCDS says they use a 74" Mac....
hotrod180 wrote:hotrod180 wrote:About the closest thing I can think of to your airplane is a Maule M4 or M5-210.
Did you ever investigate what these maules can use?
You might need to ditch the C203 (which I expect you can sell very easily),
and buy a Hartzell or different model Mac.
Have you talked to the Flight Resource folks about an MT?
A1Skinner wrote:I agree that it would really suck to cut a good 88" prop down. Can you maybe find a used 86 or 84" off of a 185 that's been upgraded?
whee wrote:....The prop shop told me that a prop at the end of its service life, ie been overhauled enough times that it is barely inside service limits, has lost 40% of its performance compared to a new prop.....
