whee wrote:
Maybe we should just take a vote. What say you guys: 86”, 85” 84” ? I’m getting the hack saw out tomorrow...
Easy to cut more off, hard to add it back on. I'd start at 86".
hotrod180 wrote:whee wrote:....The prop shop told me that a prop at the end of its service life, ie been overhauled enough times that it is barely inside service limits, has lost 40% of its performance compared to a new prop.....
I call bullshit on this one.
I removed an at-minimum length 82" C203 prop from my C180,
and installed a full-length 88" C201.
Some performance increase (not at much as I'd hoped for, of course),
but no way a 40% difference.
whee wrote: Here’s what I know. My out of the hole performance is great. However, when I roll the rpm back during takeoff I can feel a significant acceleration.
A1Skinner wrote:whee wrote:
The two prop shops I've talked to agree with Halestorm on how a CS prop 'should' be set up; just touching the fine pitch stops at max static RPM. Once the plane starts rolling the governor takes over. This may not be reality because if the engine turns too high of static rpm mechanics will lower the rpm by adjusting the governor. How often that happens I don't know and neither did the prop shop I asked.
If they are adjusting the RPM by adjusting the governor, there's a good chance they are doing it wrong. For a hartzell top prop you adjust static rpm by moving the high rpm stop on the end of rhe prop hub. This ensures you are on the stops at max static rpm...
You you are correct. But if the low pitch stop is not set flat enough on a McCauley, you can adjust the governor all you want and you still wont get max RPM.AAlexander wrote:A1Skinner wrote:whee wrote:
It's probably worth noting that this is correct for Hartzell props. Hartzell props have an adjustable low pitch stop which can be adjusted without disassembling the prop, so it's possible to run it up and make field adjustments to dial in static RPM. The Hartzell manuals discuss this procedure. The McCauley props do not have an accessible low pitch stop adjustment. To change the low pitch stop, you have to open up the prop hub, and while I haven't done this myself, looking a the McCauley drawings, it looks like the low pitch stop setting is changed by swapping spacers (although I certainly may be mistaken about that) Dialing in static RPM on a McCauley prop by changing the low pitch stops would involve multiple repetitions of removing the prop, taking it to the prop shop and having them open up the prop and adjust 75 rpm up, then 25 rpm down, etc rinse lather repeat. Reading the McCauley manual, it sounds to me like there's a standard low pitch stop setting specified for each engine/airframe installation, and then Max RPM is set with governor adjustments. The OP has a MCCauley prop but he's kind of exploring unkown territory with an experimental engine/prop combination. The the low pitch stops set for an engine that produces 20 more horsepower at 200 RPM less than his engine, so not surprising that it doesn't hit 2800 rpm on a static run-up.
A1Skinner wrote:But if the low pitch stop is not set flat enough on a McCauley, you can adjust the governor all you want and you still wont get max RPM.
DeltaRomeo wrote:"The kinetic energy of a spinning mass is a function of the square of the rotational velocity (RPM) all else being equal a prop turning at 2800 RPM has about 16% more stored kinetic energy than the same prop spinning at 2600 RPM."
A more precise means of describing what we call dumping the clutch.
AAlexander wrote:.... I don't know if you've ever flown floats in a plane with a CS prop, but you get this identical effect when you're doing your runup. When you cycle your prop from 1800 RPM, to 1400 rpm (for example) you feel that same momentary shove as the prop slows. It's also a lot more obvious that it's not a sustained increase in thrust. ....
bat443 wrote: I believe that the low pitch stop blade angle are not measured at the same blade station on the 82 and 88 inch 203 prop. I could be wrong though. Tim
whee wrote:Couple questions I've been thinking about:
1. If a constant speed propeller is removed from engine A, installed on engine B and the same max static rpm is achieved do engines A and B produce the same horsepower at that rpm?
2. Will a 88" long constant speed propeller turning 2600rpm produce more or less thrust than a 84" long constant speed propeller turning 2800rpm.
john54724 wrote:whee wrote:We paid a bunch of money to various labs and computer analysis to demonstrate the MT 2-blade 58 series in 210cm and 205cm produce less than 2% difference in thrust at all power and pitch settings so that we could allow interchangeable use on our STC's.
