30 ton? Operator in training, 250 ton Manitowoc, 200’ of stick, floating on a barge[emoji1]. No ADS-B but it does have GPS for position while dredging.courierguy wrote:Speaking of power lines....I may as well fess up, I got tangled up in some this weekend. An initial distraction, followed by other distractions was all it took. I heard a noise that sounded like a combo of POP and CRUNCH, but didn't feel anything untoward, so kept going. The first indication I had of a real problem was a women hollering "you're in the wires!"
I was in the operator cab of my 30 ton National crane, working on a project (lifting a 3,000' pound modern/new sheep camp, and setting it 50' away) for what are my closet neighbors, and the reason I mention that is I think that maybe that lulled me into, or out of, my normal work mode mind set. The initial distraction was when I first stopped on the 20% grade, thinking I was along side the area it was going to be set, and i immediately noticed the proximity of the power lines, and made a mental note.Turns out, the area was another 60' or so up the driveway. The second distraction, was the extreme slope required some special techniques to get enough dunnage under my outriggers, to get the crane level (always required) before running out of outrigger travel. These two initial distractions, combined with the nearness to my place (I could see it) in retrospect through me off my usual all business mindset. I even had my dog along,and that doesn't happen at my usual work. So once I sat my ass in the op seat, it was boom up and lets lift a sheep camp.
THE GOOD THING WAS: all I had snagged (and broken...) was the lower ground wire, the "hot" wire of the residential line was 2' vert above. I can estimate, using a little mental geometry, how close the boom tip came to the hot wire, based on the boom extension and angle, and so on and so forth. but lets just say it was too damn close! Maybe an inch or two, no more then 18-20". There is no way of knowing for sure what would have happened if I had contacted the hot, it depends on the pole's breaker, how well or not the crane was grounded, etc., but it could have been a deal breaker. A pilot buddy who also operates the smaller cranes/larger boom trucks, burned his rig to the ground (though he didn't get zapped) as it sat there and boiled off the hydraulic fluid, and then the tires. Many times, I'm told, all that happens is the nearest disconnect pops open (I called it a breaker earlier) some sparks fly, and that's about all. Other times...... My first reaction was to try to kick myself in the ass, I was pissed at my stupidity, really pissed. I got away with it, no damage at all except for what will probably be less then a $500.00 bill from the utility, they arrived from town with a 2 man crew and a small bucket truck, and were driving down the road leaving 40 minutes later. I kinda hope they sock it to me on the bill, just so the lesson sinks in real good. Exactly like in flying, complacency is the big enemy, I'm coming up on 20 K hours as an operator, and got a good (and cheap) wake up call. TOO CLOSE, WAY TOO CLOSE, indeed.
hotrod180 wrote:I've set a lot of HVAC equipment over the years,
being the guy on the roof makes you really appreciate a smooth crane operator-
esp if they obey the signal man (not all do!!!).
A good operator makes it look easy,
a bad operator just makes it dangerous.
