Backcountry Pilot • Tractor Baffle
Tractor Baffle
8 postsPage 1 of 1
Tractor Baffle
Would someone post a picture of this cooling engine baffle for a Husky???
dougs offline
Re: Tractor Baffle
You should go to the Husky Owner's forum for more information on this (flyhusky.com).
It does make a BIG difference in CHTs
Also as you probably know, this is not an approved modification i.e. the joke is they are talking about how to make a baffle for a tractor not for a Husky.
BlackWater offline
Aircraft: C 170a
Husky A-1B (now on floats)
Re: Tractor Baffle
Is the open beer part of an STC or just a log book entry?
Bill
fiftynineSC offline
Aircraft: Cessna 185F
Re: Tractor Baffle
thanks, is there any chance of twisting your arm with a picture from the front side. i dont own a Husky just thinking about applying the principle to something else. Like i said im not a husky owner so really dont want to be a member there. Not that there is anything wrong with 1.
dougs offline
Re: Tractor Baffle
Here's some pics of the Van's setup:
Sent from my iPhone using Tapatalk Pro
Re: Tractor Baffle
Lots of planes have this kind of baffle, if you're not just after Husky info. Searching with Google will find a lot of pictures. Forget the word tractor......
Re: Tractor Baffle
I've had high CHT's in my cub for years. Normal for me is 380 degrees in cruise, and in the low to mid 400's in the climb. I'd love to be able to use a method such as the "tractor baffle" to get the temps down. I might try some sort of temporary baffle to see if it works before fashioning something more permanent. Has anyone tried a temporary solution?
scottnt offline
Re: Tractor Baffle
I assume this is for a just in CASE brand tractor. :D
Now Case IH for the non farmers.
Trim
Trimtab offline
Trimtab
It can be true, even if it didn't happen - Ken Keasey - mostly*
Man invented language so he could hide the truth from others - Tallyrand - sort of
8 postsPage 1 of 1
Users browsing this forum: No registered users and 28 guests
