Transporting a big engine in your truck
Mon Jul 02, 2018 11:06 am
Whatever you do... dont put your new engine in a tire in the back of a truck.
2358
- Aircraft: C180H / C170B
Mon Jul 02, 2018 11:20 am
Bagarre wrote:hotrod180 wrote:Zzz wrote:Found a photo of how Mattituck used to do it. This is the same method Brian from Steve's Aircraft recommended to me yesterday. I guess this is how Lycoming factory also mounts them to the pallet. I guess I need to make a bushing for the mount ears, maybe out of wood.
This is so much better than putting it upside down on a tire that I'm surprised that anyone would suggest that after seeing the photo.
Besides transporting, it also looks like a good way to store the engine.
Why make wooden bushings, just use the rubber isolators ("Lord mounts") that go in the mount ears.
Off topic but now I really want to paint my motor.
X2!
5219
- Aircraft: Cessna 210J, Citabria 7GCBC, AT402/502/602
When I moved my cub home in a penskey truck I bolted the engine mount to the engine and stood it vertically on a pallet and bolted the engine mount down
Tom offline
793
- Aircraft: PA-18, C-180
Mapleflt wrote:Does red make it go faster !!!
Yes, but it makes it run hotter too.
10607
So blue would be a better choice !!!
2386
Zzz wrote:hotrod180 wrote:Why make wooden bushings, just use the rubber isolators ("Lord mounts") that go in the mount ears.
I guess because they're $179 a piece for the Lord rubbers, and it's not really a fun part to own right now.
Maybe you (or someone) has some old discarded Lord mounts?
Or maybe you can find some (fender?) washers with the correct ID / OD?
A little bit of a sloppy fit shouldn't be too big of a deal.
10607
Mapleflt wrote:So blue would be a better choice !!!
I'm old school--
I like engines to be either Lycoming Gray or Continental Gold.
10607
