ICAO wrote:For aircraft holding purposes, ICAO mandates that all turns should be made, "at a bank angle of 25° or at a rate of 3° per second, whichever requires the lesser bank."[4] By the above formula, a rate one turn at a TAS greater than 180 knots would require a bank angle of more than 25 degrees. Therefore faster aircraft just use 25 degrees for their turns.
whee wrote:I'm confused, how does either instrument help you in a vacuum failure situation? Aren't they vacuum instruments?
8GCBC wrote: I do not like either! A backup attitude indicator makes more sense.........
hotrod180 wrote:8GCBC wrote: I do not like either! A backup attitude indicator makes more sense.........
Not too worried about making perfect 2-minute turns, so an attitude indicator makes more sense to me also. An AI (aka artificial horizon) gives both pitch & bank info, whereas with a T&B or TC you need to watch the airspeed to make sure the pitch doesn't get away from you. Hence the expression "needle ball airspeed". Needle and ball centered, ASI on speed = level flight.
