I haven't the slightest idea which is preferable in IMC but if I ever find my self in an inverted flat spin, I want the turn coordinator; regardless of the weather outside. In fact, I have a vacuum powered one with a fresh overhaul tag dated 1990 something. It came from a DH Chipmunk.
The following is from an article on
The Muller-Beggs Emergency Spin Recover Procedure."Should you have no visual outside reference, the Turn Coordinator will always indicate the correct direction of yaw [from the pilots point of view] even if you are inverted, allowing the correct recovery rudder to be applied. If the needle is hard left, apply opposite “right” rudder. Remember, rudder must always be applied opposite to yaw. Do not pay any attention to the ball as this only indicates slip, not yaw, and may vary either way depending on the centre of rotation and type of spin that you are in. ie. incipient, un-stable, stable, flat, etc. One slight problem here, many aerobatic aircraft are not fitted with a turn and slip indicator." Neither an artificial horizon nor a turn and bank will help you if disoriented in a spin.
The whole article is located here:
http://www.ozaeros.net//spin/beard.htm It contains the following summary:
Situation awareness is critical when undertaking spin training.
The sky above is as useless as the runway behind.
The standard spin recovery is:
· Close the throttle and ailerons neutral.
· Identify the direction of yaw and apply full opposite rudder. Sufficient time must be allowed for the rudder to take affect.
· Lower the nose. Progressively move the stick from aft, to full forward, when spinning upright, or from forward, to full aft, when spinning inverted. Do not rush lowering the nose, and expect a fully developed spin to take up to three or four rotations to stop spinning.
· When the rotation stops, neutralize the controls, roll to wings level, and then ease out of the dive.
