Mapleflt wrote:At one time in Canada a 51% requirement that must be completed by the builder, is that still a thing ? I don't keep up on the regulations so they could have changed as well.
Are the advances in engineering and fabrication pushing the envelop on this requirement ?
If building simply becomes a assembly project does that fit with the rules as they are now ?
TR wrote:Depends on one's definition of "greater good". An analogy is assembling a pre-engineered log cabin (kit) versus designing and engineering (building) your own. In the former, all engineering is accomplished for you, in the latter, you are responsible for its structural integrity. As long as both meet/exceed the required strength to handle the required load, how one arrives at the finished product is a matter of chosen routing. I deem the "greater good" as safety vice process.
TR
StillLearning wrote:Its a kit. No engineering required, probably not even much skill or craftsmanship. I am sure some will turn out better than others. Looks like a cool thing to me, but by the time its done you'd have more into it than a decent 180 at current market prices.
StuBob wrote:Craftsmanship, shmashmanship. If you can turn a box full of parts and hardware into an airplane, you’ll know a lot more about airplanes than you did before. And that’s the purpose of the E-AB category: “education or recreation.”
As for the RV-15, the wing kit costs more than the RV-10 wing kit. I wonder what the completed costs will wind up being. Buying everything new, you’d be lucky to get one done for less than $250k, I’ll bet. Probably better budget 300. That’s about $100k more than a RANS S-21 (the only direct competition) and $100k less than a Carbon Cub.
