EZFlap wrote:BCP member 182STOL offers a very good battery upgrade featuring the sealed "Odyssey" type battery. This battery issue was the subject of some discussion on this forum a month or two ago. 182STOL's kit is apparently a bit more expensive than some other options, but this is because his battery mount is physically stronger, higher quality, and is mounted better. Apparently it is also a much easier installation process, so it may cost equal or less when you consider shop time.....
Keep in mind that this mod is not STC'd, unlike at least one of the other similar battery upgrade mods. My IA charges more to do a field approval 337 than a simple sign-off 337 for a STC'd mod-- probably because he has to spend time going over the work involved with his PMI. An STC'd mod is a slam dunk, but ya just never know whether the FAA guy will turn up his nose at a field approval-req'd mod.
