I guess these guys have no experience...
http://www.youtube.com/watch?v=Vm3kH5t5CCMhttp://www.youtube.com/watch?v=-aGolOOo ... re=relatedhttp://www.youtube.com/watch?v=bPSElw8q ... re=relatedhttp://www.youtube.com/watch?v=8RQGSVf- ... re=channelhttp://www.youtube.com/watch?v=H-Mqau9V ... re=channelhttp://www.youtube.com/watch?v=zbozrPXhGNw&feature=fvsrNot to mention from the Syllabus that you should have followed when getting your private certificate:
Short Field Takeoff practical test standards
Short field takeoffs are utilized when it is necessary to get off the ground in the minimum distance and climb relatively steeply to clear obstacles. Many trainers such as the Cessna 152 call for use of 10 degrees of flaps for the short field takeoff. Once pre-takeoff checks are complete, set flaps as appropriate prior to taxiing onto the runway. Taxi onto the runway and stop at the very beginning of the runway so no distance is wasted.
While using your toes to apply the brakes and hold the airplane in position gradually add full power. Check the engine instruments and tachometer for normal indications prior to releasing the brakes.
In a real short field situation, it’s important to know the airplane is developing full power before attempting to take off with a short runway or obstacles to clear. Hence the run-up to full power prior to brake release. The run-up also prevents wasting runway while you add power. Assuming all indications are normal, release the brakes and accelerate down the runway to rotate as normal and commence a climb out at the recommended obstacle clearance speed or best angle of climb speed, Vx. This will be a more nose high attitude than you have used previously and you will need to be attentive to precise airspeed control. Also, because of the high power setting and high angle of attack, you need to use plenty of right rudder to overcome left-turning tendencies. After clearing obstacles, lower the nose slightly and accelerate to best rate of climb speed, Vy. With a positive rate of climb established, retract the flaps and continue the upwind climb as normal.
In a real short field situation, be particularly attentive to maintaining the correct airspeed. Only the recommended obstacle clearance speed, or Vx, will give you the best angle of climb. Anything faster or slower will not work as well.
AND WHILE WERE ON THE TOPIC OF TAKEOFFS: HERE IS SOFT FIELD TECHNIQUE FOR YOUR REVIEW:Soft Field Takeoff and Landing techniques are good skills to have even if you have no intention of exposing yourself or your airplane to the challenge of a real soft field. Most people will learn these techniques on a regular paved runway and seldom, if ever, get to put their skills to work on a real soft field. However, you will definitely be tested on this as part of the private pilot practical test and, in the event of an emergency landing off airport, you will be glad to have this skill available.
To develop your soft field technique, visualize mud. Your objective is to maintain directional control and not get stuck. With just three small wheels and a propeller to work with, this could be challenging. Fortunately, all of your control surfaces can be of use in keeping things rolling and pointed in the right direction. Before you start your taxi, get organized and complete all necessary pre-takeoff checklists so, that at least in theory, you can keep rolling all the way to the runway and take off without stopping. Because of constraints imposed by control towers and crowded tie-down areas etc., you probably will not get to practice this part. A real soft field taxi will require more power than usual to get started and probably more than usual to keep rolling. In a tricycle gear airplane, taxi with the control wheel held all the way back to minimize weight on the nose wheel. The nose wheel is the most likely to get bogged down, so do what you can keep it light.
In many airplanes such as the Cessna 152, the soft field takeoff is performed with 10 degrees of flaps extended. If flaps are to be used, extend them as you taxi onto the runway. In a real soft field situation, tower and traffic permitting, you would taxi onto the runway without stopping and, once lined up on the centerine, apply full power with the control wheel still in the full aft position. You want the nose wheel to come off the ground at the first possible opportunity, but not so swiftly that the airplane rears up and scrapes it’s tail on the ground. Most trainers have a tail tie down skid installed to lessen the consequences of scraping the tail. As you add power and accelerate, airflow over the elevator will increase and it will become more effective at raising the nose -- so much so that you will probably need to reduce the backpressure on the control wheel slightly to allow the nose wheel to lift off without the tail scraping. As you add power, you also need to add right rudder to prevent your airplane from unexpectedly exiting the runway to the left due to normal left-turning tendencies that are at their most noticeable in high power/high angle of attack situations.
The idea is to get unstuck from the runway at the first possible opportunity and then build up airspeed in ground effect before attempting to climb out. So, you accelerate down the runway with the control wheel positioned further back than for a normal takeoff. The nose wheel will lift off first and, as you continue to accelerate and maintain directional control with rudder the main wheels will lift off. This happens at a lower airspeed than for a normal takeoff and below the speed at which it is safe to climb out. As soon as all three wheels are off the ground, move the control wheel forward to lower the nose into a straight and level attitude. This allows the airplane to build up more airspeed in ground effect before attempting to climb out.Lowering the nose at this point takes some willpower, since it is not intuitive to lower the nose immediately after liftoff when very close to the ground.
It is important, however, that you do not attempt to climb out of ground effect until your airspeed is at least at best rate of climb speed, Vy. For the purpose of learning/demonstrating your soft field takeoff technique, if the runway environment permits, you may fly along in ground effect a little longer than is strictly necessary. Contrary to what every bone in your body is telling you as you try this the first time, you are unlikely to fly yourself back into the ground unless you are really heavy-handed and not paying attention. You may be heavy-handed but it’s safe to say you’ll definitely be paying attention during this challenging task. Once the desired airspeed is attained, pitch to begin your climb by applying a little backpressure; then climb out at best rate of climb speed, Vy. Once a positive rate of climb is established, retract the flaps and continue the departure as normal.
