Backcountry Pilot • Whee's Bearhawk Project...Airworthiness Certificate issued!
622 postsPage 17 of 321 ... 14, 15, 16, 17, 18, 19, 20 ... 32
Re: Whee's Bearhawk Project...progress.
Wow Jon...looking super...i could never do it!? if u need a stress relieving snowmobile ride this winter, im your guy.....!
jomac offline
jomac
jomac wrote:Wow Jon...looking super...i could never do it!? if u need a stress relieving snowmobile ride this winter, im your guy.....!
Thanks Jo! I'm not sure how it would look for the manager of the Polaris shop to go riding with a guy on a Arctic Cat wearing MF gear 8)
Sure it would...say get out an old 500 Indy and a sled to carry Arctic Cat repair parts and tools.... On a side note....I've been told...buying an Arctic Cat is grounds for divorce...
m_moyle offline
Aircraft: Piper PA 20
Shhh! Don't tell my wife that, I like my Arctic cat!
Plane is looking good Whee! I like the nostalgic Luscombe touch.
Whee, does the German Shepherd get to go on flights with you?
DeltaRomeo offline
Aircraft: M5 180C
DeltaRomeo wrote:Whee, does the German Shepherd get to go on flights with you?
Duke used to fly with me pretty regularly and the seating is arranged so he will fit in the BH with the family but he's a big dog so unfortunately I doubt we'll be able to take him on camping trips with the family.
Had to fit the firewall and boot cowl so we could cut a new instrument panel.
Haven't nailed down the panel layout but I thinking something like this...maybe.
We will probly ditch the 430 and go with a Garmin GTR200 or a Icom A220. The T&B won't get install unless we decide we want one. All the switches and the key will go on the far left.
I know your plan is just for VFR flight, but I'd stick an attitude reference in there. I've got a TruTrack ADI and love it. Found mine used for pretty cheap (included the backup battery). You might could do the same.
Looking great! 430 is a waste unless you're going IFR certified.
Can't say enough about the GTR200. For me, it's a bit more user friendly than the A220. Better squelch as well IMO. The standby chanel monitoring feature is a must have!
Sent from my SM-N910V using Tapatalk
TradeCraft offline
CamTom12 wrote:I know your plan is just for VFR flight, but I'd stick an attitude reference in there. I've got a TruTrack ADI and love it. Found mine used for pretty cheap (included the backup battery). You might could do the same.
The GRT Sport EX is my primary attitude indicator. In my mock-up I'm using the engine display because that is how I plan to use it most of the time. If I decide I want a attitude reference I can flip to this screen:
Or this one:
Or this one:
:D
TradeCraft wrote:Looking great! 430 is a waste unless you're going IFR certified.
Glad to hear a good report about the GTR200. It looks like a great radio. I agree about the 430 but eventually I want to get my IFR rating so I'm trying to make sure I have room for the necessary equipment.
Whee - did you remake your panel because you wanted it a little taller? I can appreciate that, if so.
For self-evient reasons, Bob's panel wasn't sized for modern large-screen avionics. Most fit, but it's tight.
The original panel we cut forced the boot cowl into a shape I don't like, it had slight flat spots near the door post. The new panel will be the same height as in the plans but is shaped so the boot cowl curves more smoothly. There is really just a tiny difference. The 7" GRT Sport fits the panel quite well.
That's looking great Whee!
hardtailjohn offline
Cool! Good deal, stuff that can do more than one thing is good!
Nice job Whee! Lookin awesome, I like the changes on the instrument panel!
HawkRT offline
Aircraft:
Bearhawk (AviPro Quickbuild)
260hp O540 Lycoming
Hartzell CS
Aux Tanks - 72gal total
EDO 2870 Floats
8.50x6 tires
Not much to report. My dad has been working on the door panels and fuel lines.
Last night I started welding up the rear seats.
So I have a question about skinning the doors... How did you figure out where to drill the holes in the outer skin to ensure you hit the centerline of the tubing for the door? I'm having a dickens of a time figuring that out on my Bearhawk Patrol.
JP256 offline
Aircraft: Rans S-6ES
If you want to be right on the centerline of the door frame tubes I think the best way is the drill the door tubes first then use a match drill jig to drill the aluminum skins.
The way we did it was lay the frame on the outside of the skin, trace the outside edge of the frame then measure in half the diameter of the tube and draw another line. We then clamped the skin and frame together as they would be when finished and drilled along the second line. We weren't worried about having them exactly on the centerline.
Well, DOH! Not sure why I didn't think of drilling the frames and using the match-hole drill jig... Guess I know what I'm getting myself for Christmas!
JP256 offline
you guys are talented...looking awesome jon.....!
jomac offline
jomac
