Backcountry Pilot • Whee's Bearhawk Project...Airworthiness Certificate issued!
622 postsPage 31 of 321 ... 28, 29, 30, 31, 32
Re: Whee's Bearhawk Project...Airworthiness Certificate issu
Couldn't get the second one to come up, but never the less that's very cool, Whee!!! Great job on the whole thing!!! Now you gotta fly it up here! ;)
hardtailjohn offline
Thanks guys! Looks like we got the leak fixed and my dad flew the plane yesterday evening.
John, I’ll definitely have to come up for a visit.
I think I fixed the video link.
whee wrote:Thanks guys! Looks like we got the leak fixed and my dad flew the plane yesterday evening.
Congratulations!
What caused the leak?
Sent from my Pixel XL using Tapatalk to specifically annoy:
Zane
Hammer
TradeCraft offline
Me. I failed to torque the tach drive.
Had miss something. Glad it was an easy fix.
Zane
Hammer
TradeCraft offline
Good to hear! Glad you gotter Jon!
whee wrote:Me. I failed to torque the tach drive.
Did that fix the low oil pressure too? How are your CHT’s?
akschu offline
Contributing author
Aircraft: 1949 C-170
20?? 4 place Bearhawk
No, oil pressure is still on the low side. Spec is 30-60psi at cruise. We are seeing 30-32psi.
CHTs have been cool, highest being 360F, but the engine hasn’t been throughly heat soaked yet. A 20min flight flight isn’t enough to tell how anything is doing.
Did you put a new spring in the pressure relief or did you use the old one? Might be worth the few $$ to try s new spring.
I put a new springs in it; this style takes 2 springs.
Whee, I am so happy for you, its been a long road. Enjoy!
Have you checked the indicated oil pressure in the cockpit against a calibrated device? I know of one engine shop that says if you have them do the overhaul, they already checked the pressure and would rather you don't mess with the engine based on what your cockpit indication is until you have verified that it is correct.
Troy Hamon offline
Aircraft: Piper PA-22
Thanks Kurt! It has been a long time coming. Now to enjoy the result.
I hear ya Troy, thanks. The EFIS manufacturer says if the oil pressure indicates zero before starting then it is accurate. I still plan to check the oil pressure with a manual gauge when I pull the cowl next. I’d really like to get an couple hours of run time on the engine before I do more ground running.
whee wrote: ...I’d really like to get an couple hours of run time on the engine before I do more ground running.
My friend, this seems illogical in the grand scheme of death prevention. #-o :P Are you just concerned about overheating the engine during ground running?
Probably ring-seating.
Haha, point taken. If I was at all suspicious of an erroneous indication I would agree. I'm confident that the indication is correct and that the relief valve isn't adjusted properly or something else. The pressure is still in the green so I'm comfortable flying the plane but when we pull the cowl after the next couple flights we will take the precaution and verify the gauge.
Glazing the cylinders is my main concern with additional ground running. Being cautions while still properly breaking in a fresh engine is proving challenging on a new EAB airplane. But yeah, death prevention is number one. Can't wait to see how you balance that risk Z. :wink:
whee wrote:But yeah, death prevention is number one. Can't wait to see how you balance that risk Z. :wink:
GULP.
Congrats Whee!!! When are we going camping? :P
blackrock offline
Aircraft: Bearhawk
whee wrote:.... The pressure is still in the green so I'm comfortable flying the plane.....
Key point.
Airworthy, and safe-- just needs tweeking to be optimum.
IMHO
Awesome progress Whee! Congratulations.
You are going to love this summer.
Allan
albravo offline
