Hello all,
I don’t want to start the wheel landing versus 3-point debate, but was hoping for some tips.
I have been mostly a 3-point pilot for years and decided I would really like to get more comfortable with wheel landings. Partly just to have another tool in the tool box, and frankly with gusty winds the idea of being able to get the mains on before stalling sounds appealing.
I started off practicing on grass on calm days and worked up a scheme that works well for me (70 mph on final, full flaps and 1500 rpm).
This weekend I got what I thought would be anice training day with winds 5G15 which varied 30 degrees either side of the runway heading. It was a mess. Using my recipe above I kept bouncing. Finally I decided to bump up the airspeed to 80 (thinking of the quote to add half the gust to your airspeed) and it seemed to soften the descent rate, as expected, but i touched down was so fast that once it became a pretty jarring ride and I would ultimately power up and go.
I would like to blame the runway, but you all land off airport. So, I should be able to land on a flat grass runway even if it isn’t the smoothest.
At 70 with a headwind, I guess that converts to 60ish ground speed, does that give me a different effective descent rate that could explain the bounces?
80 seemed too fast and will burn up a lot of runway and is awful jarring.
Any thoughts or suggestions? What modifications do you make when wheel landing in gusty conditions?
Thanks
