Zane wrote: Many of the most serious problems with our traditional aircraft engine designs like Continentals and Lycomings come from the fact that they are air-cooled, and suffer from uneven cooling of the cylinders on even the most well-baffled and flow-optimized cowlings. This makes it difficult to optimize mixture and CHT/EGT for all cylinders, meaning one or two are always running cold or hot.....
For being such old-fangled pieces of junk, the O-200 is a helluva good engine. If you consider the similarity of all of the small Continental 4-bangers, A-65 through O-200, it's hard to argue with about 75 years of success. If you want, you can get electronic ignitions for them, & higher compression pistons for a little more steam. I consider air-cooling a pro, not a con-- ditto for direct drive (no reduction drive/gearbox hassles). For bigger non-LSA airplanes, jump up to the 320 or 360 Lycoming. Old-fangled, true, but time-tested & as close to bullet-proof as you can get.
The alternative engine I like most is the jabiru-- just a pimped out, machined-from-billet old-fangled air cooled flat engine with a trick ignition. Next would be a VW or Corvair-based conversion. You can keep all your 2-strokes, diesels,and/or water-cooled automotive engines.
My two cents anyways.
