Backcountry Pilot • Whiskey Compass Rebuild Instructions?
39 postsPage 1 of 21, 2
Does anyone have a copy of the instructions for replacing the gaskets/fluid? The kit came with the three gaskets and the fluid, but no instructions.
C180_guy offline
Re: Whiskey Compass Rebuild Instructions?
Hmmmmmm...no instructions are provided as instrument repair shops have to do the dirty deed. A&P's apparently are excluded from that Club.
However.......some years ago this was apparently common knowledge to some enlightened Alaskan Bush drivers in need of flight direction. I heard about it via the Bush radio one winter's eve while listening to Fleetwood Mac's 1977 album "Rumors" under a full Aurora. Where's Stevie Nicks when we need her?:
https://www.dugbert.com/flying/rans-s-1 ... ss-rebuild
If's there a fill plug on top use that. Then submerging the instrument in the supplied liquor will remove any bubbles then cap the home brewed container I heard.
Gary
PA1195 offline
Buy a vertical card compass and you will never get leaked on again.
https://www.aircraftspruce.com/catalog/inpages/vertcard_compass3.php
Yes, it's more expensive but whiskey compasses will leak from more places than the gaskets. And nobody likes wearing the compass fluid on a long cross country. Just think of it as the opportunity to upgrade to a better device.
DeltaRomeo offline
Aircraft: M5 180C
niente qui
dogpilot offline
Took ball and went home
Dogpilot, did you bolt it down or use the adhesive mount? I need a new compass and that one looks good; the reviews all seem positive as well. If you got the lighted option, do you find the blue light to be obnoxious, or is it dim enough that it isn't a nuisance at night?
colopilot offline
Aircraft: 57 182A
niente qui
dogpilot offline
+1 on the S.I.R.S compass. It's fantastic. It replaced a vertical card compass that had serious issues (it would spin around and around at certain engine rpm). I put in the S.I.R.S. and haven't looked back. A close friend of mine tried rebuilding his airpath compass, replacing seals and refilling while immersed in fluid, but could never get the seals completely tight, so the leak persisted. He, too, went to a S.I.R.S. . . .
CAVU
CAVU offline
I put a S.I.R.S. Compass in my 170 a number of years ago. Mounted with the stick on to windshield mount......and did it stick! Thing swung great, simply the best aircraft compass out there.
niente qui
dogpilot offline
DeltaRomeo wrote:Buy a vertical card compass and you will never get leaked on again.
I have had terrible luck with VC compasses. Nothing internally to take any shock or vibration. The S.I.R.S. looks like the way to go, and will be going in my 206. If I had a good whiskey compass I'd just rebuild it and use it. I've not had much trouble with them leaking all over me.
I'm game for a SIRS; I haven't purchased the VC compass yet; I'm just not going to give my "whiskey" compass any more ammo to puke on me with :evil:
DeltaRomeo offline
Aircraft: M5 180C
After reading the responses and thinking this through, I think I will not entertain repairing the 60 year old compass (that never compensated worth a darn). Time to replace.
C180_guy offline
And, for thos naysayers who argue that a compass is totally useless in this era of GPS, I have, on two occasions, had a GPS check out for more than an hour, and with no other means of navigation than a compass. Those times, that S.I.R.S. compass saved the day handily.
X2 on the SIRS. Adhesive mount to windshield 6 years ago. 4 of those years were the freeze / thaw variety in Alaska before I became a hangar softy. I’ve hit it hard many times accidentally grabbing the v-bracein turbulence. Sucker is stuck!
akgreg offline
Aircraft: Yes
For the older compasses, getting the air out is really easy with a small vac chamber. A syringe tip is jambed in the fill port with a couple cc's of fluid, put the mess in a vac chamber and run the pump for a minute to expel the air, then slowly let it come back to ambient pressure to get the compass to suck in fluid. Repeat once or twice as needed.
lesuther offline
Okay, I just gotta ask: What line of work or hobby are you involved in that results in having a “small vacuum chamber” handy?
:shock:
While waiting for a reply regarding vacuum assisted devices (hopefully not just those used for personal pleasure), I use charcoal lighter fluid as the fill medium. Cut the top off the container and drop the compass in and roll it around to fill. Then use same fluid for a BBQ to celebrate the repair.
Gary
PA1195 offline
niente qui
dogpilot offline
Just a simple question.....no need to get into your favorite suction device. :arrow: My question was about a “vacuum chamber”.
Kingsford odorless charcoal lighter: http://sds.chemtel.net/webclients/chene ... 654SDS.pdf
AKA deodorized kerosene via Chemical Abstracts Service #64742-47-8 (https://www.cdc.gov/niosh/ipcsneng/neng1379.html). We used to call it or similar products Stoddard Solvent or Varsol which is used for washing parts and engines.
Note the link to use as a compass filler: https://en.wikipedia.org/wiki/White_spirit
I hope MTV eventually gets his vacuum figured out.
Gary
PA1195 offline
