PA1195 wrote:I had two planes with a remote compass...transmitter in the outboard wing and vertical card display. Seemed to work well but maybe they're no longer favored. In reality Alaska and Canada are favored with enough terrain and surface features to make VFR pilotage easy once learned.
The compass correction card in my Taylorcraft has long since lost its numbers but the compass is current with adjustments.
Gary
mtv wrote:PA1195 wrote:I had two planes with a remote compass...transmitter in the outboard wing and vertical card display. Seemed to work well but maybe they're no longer favored. In reality Alaska and Canada are favored with enough terrain and surface features to make VFR pilotage easy once learned.
Gary
So, Gary, you don't recall the Slope the Y/K Delta and/or the Yukon Flats in 3 mile vis????
hotrod180 wrote:I was surprised that someone asked about instructions.
A1Skinner wrote:I have had terrible luck with VC compasses. Nothing internally to take any shock or vibration. The S.I.R.S. looks like the way to go, and will be going in my 206. If I had a good whiskey compass I'd just rebuild it and use it. I've not had much trouble with them leaking all over me.DeltaRomeo wrote:Buy a vertical card compass and you will never get leaked on again.
https://www.aircraftspruce.com/catalog/inpages/vertcard_compass3.php
Yes, it's more expensive but whiskey compasses will leak from more places than the gaskets. And nobody likes wearing the compass fluid on a long cross country. Just think of it as the opportunity to upgrade to a better device.
Interesting. I've talked with a couple different avionics shops that wont even sell VCCs because of ho unreliable they are. Seems I'm not the only one that has problems that stem from more then just a mounting issue. If they work good for you then great, but personally I'll stay away.JP256 wrote:A1Skinner wrote:I have had terrible luck with VC compasses. Nothing internally to take any shock or vibration. The S.I.R.S. looks like the way to go, and will be going in my 206. If I had a good whiskey compass I'd just rebuild it and use it. I've not had much trouble with them leaking all over me.DeltaRomeo wrote:Buy a vertical card compass and you will never get leaked on again.
I've had PAI-700 VC compasses in the last three aircraft I've owned, and had excellent performance from all of them. However, the very first one I had would sometimes "stick" on a heading, not moving or bouncing around. (This also made it very difficult to accurately "swing" the compass.) I thought it was 'worn out' from all the bouncing and vibration, so I spoke to the folks at Precision (who make the PAI-700) about it. They immediately asked about the mount I was using. Turns out it was the wrong one for my airplane, and that it was completely worn out because of improper installation. In effect, my VCC was "hard mounted" to the windshield mount, like you would mount a SIRS or "whiskey" compass. This is NOT correct for the PAI-700, which needs to have a "cushioned" mount (special density foam in compression) that allows the compass to move a little bit, but dampens out the vibrations from the airframe and engine. The reason my compass would 'stick' occasionally is that it was unable to move freely (jiggle), which prevented the geared mechanism from working as designed. Turns out the Precision PAI-700 (and probably the other VCCs which work on the same principles) are REALLY tough internally, and highly resistant to vibration and shocks. Enough so that if you don't have the right mount that allows controlled movement, they will NOT work correctly!
Since that first airplane, I've encountered several other owners who had a VCC that "just didn't work right". In each case, when I looked at their mount, it was NOT the recommended mount for their airplane, and when the mount was replaced with the recommended one, they found the VCC was amazingly good. If you've got a VCC and don't like the way it behaves, you may want to talk to them about the mount for your particular airplane. (By the way, they send you to Aircraft Spruce to purchase the mount... They apparently stock them all.)
lesuther wrote:https://aircraftspruce.com/pages/to/hand_compass/compensator.php
These have worked for around 170 years, if so inclined. They're also broadly referred to as binnacles.
akgreg wrote:lesuther wrote:https://aircraftspruce.com/pages/to/hand_compass/compensator.php
I didn’t think it was possible to have balanced balls?
