Adding to my comments earlier, regarding WAAS for approaches. There are non-WAAS GPSs which can shoot non-precision GPS approaches, but having the WAAS capability means that you can shoot precision GPS approaches as well--and that's just exactly like flying an ILS.
Not certain where you are in your IFR training, but let's look at a quick recap of approaches. There are essentially 2 categories, precision and non-precision.
A precision approach is one that gives both lateral/horizontal guidance and vertical guidance. At the end of the approach, the lowest the airplane can be descended to is called a decision height or decision altitude. If the runway environment isn't visible at that point, the pilot must go around.
A non-precision approach provides lateral guidance but only designated altitudes, and the pilot has to refer to the altimeter to fly the airplane at those altitudes. Instead of a DH/DA, the lowest the pilot can go is called a minimum descent altitude, MDA. But the go around point is determined not by that altitude, but instead by timing from the final approach fix. Those times at different ground speeds are printed on the approach plates of non-precision approaches.
Without using GPS, within those 2 categories, the only precision approach is an ILS, which provides both lateral guidance and vertical guidance.
Without GPS, non-precision approaches include LOC (localizer only), VOR, and NDB (ADF) approaches.
Using GPS, within those 2 categories, the only precision approach is an LPV (localizer performance with vertical guidance). For practical purposes, this works just like an ILS. There is also LNAV/VNAV (Lateral/vertical navigation), which is very similar, but it's not as accurate as an LPV because the "beam" doesn't narrow as the airplane approaches the runway. While both of these approaches will have both vertical and horizontal guidance, the LNAV/VNAV approach will have higher minimums due to that lesser accuracy, but both have a DA/DH. Because of that lesser accuracy, it's not considered a precision approach, but it is flown the same way. Both of these approaches require a WAAS receiver.
Using GPS, the remaining non-precision approaches are LNAV (Lateral navigation), LP (Localizer performance--more accurate laterally than the LNAV), and one that's just called GPS, which is just like an LNAV. None of these approaches provide vertical guidance, and all of them have an MDA. None of these require a WAAS receiver, but the receiver must nonetheless be approved for approaches (some GPS receivers are approved only for enroute IFR use).
You may be wondering why so many types of GPS approaches, and the best answer is that the GPS system started simply--no approaches, and only enroute guidance. Then simple GPS approaches were created overlaid upon existing VOR and NDB approaches. Then as technology improved and became more trustworthy, GPS only approaches were created, and soon that morphed gradually into the more precision approaches aided by WAAS. Here's a pretty neat summary article:
http://www.aviationsafetymagazine.com/i ... 164-1.htmlThe bottom line of this is that if you want to take advantage of the best that the GPS system has to offer, you need a WAAS receiver. So far as I know, the least expensive way of doing that is with a 430W. Although they're no longer made, Garmin promises that they'll be supported into the foreseeable future. There are used ones available. There are also used non-WAAS 430 receivers available, which Garmin will modify to be a 430W, for something like $2800, and although they're completely rehabbed in the process, their processor is a little slower than the 430W as factory made.
More information than you probably wanted to know. Sorry about that!
