180BarkinWagon wrote:I ran the full size iPad with the Ram mount doing some photography work. I was really pleased with the mount itself, I hate almost every other Ram mount. I can't say I'd recommend the full size for a full-time mount location on the yoke. I did block the view to my egt/cht, suction gauge and part of the VSI. Basically any instrument on the bottom row and the switches on the bottom row. While it doesn't interfere with your hands in level flight I didn't like it when I did steep banks. The charging cord was another issue of being in the way. I didn't have a glare screen on it, but it does need something as it wasn't always clear.
If you don't have a problem seeing the information on a mini iPad I would suggest it. I didn't own the large iPad shown, but if/when I buy one it will be a mini. I don't have any experience with the mini Ram mount however.
Nosedragger wrote:Thanks all. Sounds like mini is not necessary. Warning to others, ipads are the only ones you can use with foreflight. I bought a samsung galaxy tablet first because I had a samsung galaxy phone. Noooo workey with foreflight.
Scolopax wrote:180BarkinWagon wrote:I ran the full size iPad with the Ram mount doing some photography work. I was really pleased with the mount itself, I hate almost every other Ram mount. I can't say I'd recommend the full size for a full-time mount location on the yoke. I did block the view to my egt/cht, suction gauge and part of the VSI. Basically any instrument on the bottom row and the switches on the bottom row. While it doesn't interfere with your hands in level flight I didn't like it when I did steep banks. The charging cord was another issue of being in the way. I didn't have a glare screen on it, but it does need something as it wasn't always clear.
Barkinwagon, there is an arrangement that I found with the ram mount where the link is positioned on the bottom of the yoke parallel to the yoke tube, where the iPad can slide between the rams horns and nestles in very close to the Cessna badge on the yoke parallel to the badge surface. It was hard to visualize before I configured it this way, but it fits beautifully. It is the best way to get the screen low and as close to the yoke as possible. It doesn't interfere in any way through the full range of control travels. I will take a photo and post it this weekend.
Scolopax wrote:Scolopax wrote:180BarkinWagon wrote:I ran the full size iPad with the Ram mount doing some photography work. I was really pleased with the mount itself, I hate almost every other Ram mount. I can't say I'd recommend the full size for a full-time mount location on the yoke. I did block the view to my egt/cht, suction gauge and part of the VSI. Basically any instrument on the bottom row and the switches on the bottom row. While it doesn't interfere with your hands in level flight I didn't like it when I did steep banks. The charging cord was another issue of being in the way. I didn't have a glare screen on it, but it does need something as it wasn't always clear.
Here is how mine fits:
I am on the taller side of average, and when in cruise and climb attitudes, I have no trouble seeing all of my gauges without moving my head. In a steep descent, I might need to lean forward a bit to see the bottom row, but it is a small inconvenience that is easily neglected in comparison to the convenience of having Foreflight so readily accessible.
And if I want to stow the iPad, no issue at all.
