170 inspection easter eggs
This subforum is meant to organize Cessna 170-related topics.
Not an all encompassing list, YMMV (your mods may vary) but if you're new to the 170 or looking to buy one this is pretty helpful. Cheers
Annual special items.pdf
- Annual insp special items
- (82.72 KiB) Downloaded 463 times
redacted on Fri Dec 23, 2022 3:20 pm, edited 1 time in total.
redacted offline
58
- Aircraft: Cessna 170
This is fantastic intel, thanks
2324
- Aircraft: Cessna S170B NexGen (NM) Variant
redacted wrote:Not an all encompassing list, YMMV (your mods may vary) but if you're new to the 170 or looking to buy one this is pretty helpful. Cheers
Thank you for sharing this information.
CubbyChubby offline
18
First annual done. This list came in handy, the flap handle rod connection mentioned was a new one for my mechanic and he has lots of Cessna experience. Also I found two radio knobs and a screwdriver in the belly. I was only missing one radio knob.
redacted offline
58
Might want to add the Aileron Carrythrough cables at the top of the fuselage where the three small pulleys are. Area of high wear on the cables because there is not really sufficient angle change to move the pulley. I've had to do two replacements of the aileron carrythrough because of fraying, if you rotate the carrythrough where it touches the pulley, you'll see the wear. It looks fine until you turn it over.
WorkingWarbirds offline
92
- Aircraft: Champion 7GCBC
Mooney M20E
Globe Swift
