DENNY wrote:If you picture is you, then you are young, you don't need no stinking hanger!! Get up early, sweep snow pre-heat and go. Insurance, just get liability, if you wreck it work nights to pay it off you can sleep when you die!! The big question is how are you going to get the wife to come to ALASKA?????
flynbeekeeper wrote:....My first airplane was a 172. That would be my advice to you. 2/3 the price of a 170, park it outside. Cheap! At this point in your life, time spent flying is more important than the "taildragger sex appeal" thing. Always easy to trade up later.
formandfunction wrote:Are there no wing options for the pacer? That might be a quick solution to high da.
Reality is we almost all suffer from high da/turbulence and I don't know many people that fly much after lunch. It's just part of it. Doesn't matter how big your engine is when the wind starts ripping. True your margin is wider with a big engine but there's still a margin.
Battson wrote:formandfunction wrote:Are there no wing options for the pacer? That might be a quick solution to high da.
You can do extended wing tips for the Pacer, they are quite an extension and do make a difference
DENNY wrote:Changing a round tip wing to a square tip can add both speed and lift to a wing. Because now the wing is not working so hard, the round tip is just not as effective as a square tire wing. Dakota cub found this when they made the similar wing for the Supercub. I would NOT buy any starter airplane with intent of making it better!!! That is a money pit!!! Buy the plane you need for the mission today!!! For a starter plane a good 172 or Tripacer would be fine(lots of square tip pacers/tripacers around). Buy the trainer and learn to fly. Spend NO MONEY on changing the plane!!!! Sell it when the training mission is done and then spend the money on a plane for the next mission!!!
DENNY
G44 wrote:DENNY wrote:Changing a round tip wing to a square tip can add both speed and lift to a wing. Because now the wing is not working so hard, the round tip is just not as effective as a square tire wing. Dakota cub found this when they made the similar wing for the Supercub. I would NOT buy any starter airplane with intent of making it better!!! That is a money pit!!! Buy the plane you need for the mission today!!! For a starter plane a good 172 or Tripacer would be fine(lots of square tip pacers/tripacers around). Buy the trainer and learn to fly. Spend NO MONEY on changing the plane!!!! Sell it when the training mission is done and then spend the money on a plane for the next mission!!!
DENNY
Excellent advice!
WWhunter wrote:X2!!! Too many people try to jump into their dream with both feet and a empty wallet. I think most of us have probably done the same and have learned from it. Nothing wrong with getting a 172 or Tripacer to build time in. They are much cheaper to insure, maintain, and learn the basics until you can fly them like they are a part of you.
