TradeCraft wrote:WWhunter wrote:X2!!! Too many people try to jump into their dream with both feet and a empty wallet. I think most of us have probably done the same and have learned from it. Nothing wrong with getting a 172 or Tripacer to build time in. They are much cheaper to insure, maintain, and learn the basics until you can fly them like they are a part of you.
How is a 172 or Tripacer any cheaper to maintain than a 170 or a Pacer?
Spdcrazy wrote:I am a low time pilot for sure. I soloed last month is all. I expect (if I actually buy something) it'll have a metal prob and electric start.
As someone asked earlier. I to would like to know what makes a pacer or the like more expensive to maintain than a c172? I understand insurance will be a tad higher, but I won't desire to sell the pacer/etc as quick as the 172. In fact it might even fit my bill when I move to AK. I don't want to push thing, but if I can learn in a pacer just as well as a c172, then I'm tempted.
I'm early enough in my learning that if I am to buy, earlier the better. Less giving my money away to someone else.
Troy Hamon wrote:
Fabric Piper airplanes usually have cheaper parts than metal Cessna airplanes. Example, Cessna spinner for 172 is over $1,000, spinner for O-320 on a Pacer is $500.
However, if the airplane is parked outside, the concern is that the fabric might age out and need replaced, at which point the cheaper parts on the Piper pale in comparison to the cost of a recover.
So...it depends...
WWhunter wrote:TradeCraft wrote:WWhunter wrote:X2!!! Too many people try to jump into their dream with both feet and a empty wallet. I think most of us have probably done the same and have learned from it. Nothing wrong with getting a 172 or Tripacer to build time in. They are much cheaper to insure, maintain, and learn the basics until you can fly them like they are a part of you.
They're not! Probably should have re-edited that better. I had that response in a paragraph comparing that costs to what a lot of guys use in AK (Beaver,180, 185, 206, etc). In my attempt to shorten my post I deleted that part and now see the errors of my ways. I was attempting to post advice in purchasing something that is easy to insure, maintain, etc and learn the basics before jumping into his dream plane. Can't get anything passed you guys. I'll crawl back into my cave and be quite.
Man, you guys can get a plane covered for 14000? In Canada you'd get a terrible cover job for that. It's pushing closer to 40k for a good cover job here...Prosaria wrote:Hangars for Fabric Planes:
There are hundreds of fabric planes that live out their lives outside all year up here. That is the last thing that would be a consideration for me. Take the minimum of $7k per year for a hangar and you can recover your plane every two or three years.
$25-30K with good paint.A1Skinner wrote:Man, you guys can get a plane covered for 14000? In Canada you'd get a terrible cover job for that. It's pushing closer to 40k for a good cover job here...Prosaria wrote:Hangars for Fabric Planes:
FYI, toilet paper is not a recommended covering material...Prosaria wrote:As quickly as they fall apart when exposed to sun or rain, you will get really good at recovering. Save some money on labor and a $14k recover is possible.
By the third or fourth time you forget to pull it into the hangar for the night, you will have learned your lesson.
DENNY wrote:When it comes to upgrades. It is very hard to get any of your money back from upgrades. Say you buy that Pacer for 30 grand with the plan to upgrade to a 180 hp. Now you have just stuck in another 30-40 grand!! The plane will be worth about 45 grand now. It is much cheaper to find and buy the plane already built the way you want it then to upgrade. Labor is 100 dollars an hour. To do a proper recover job you should also put the frame in a jig and fix any bad tubing. Did you want a skylight while you are doing your recover?? A new 180 horse and you should get a proper 4 cylinder EGT/CHT. The snowball effect happens fast!!!!!! Find a plane to fit the training mission. Fly it and change nothing for 300-400 hours just add fuel and fly. Sell the plane for a few grand less then what you paid. Find a plane already built for the next mission. Rinse, wash, and repeat. What you really need now is hours if your plan is to come and fly for a living in Alaska. The majors are pulling a lot of young pilots out of the fun bush jobs so if you have 500hours and a commercial lic you could most likely get a job.
If you plan to come up and start your own 135 company. You will still need to fly up here for a few years to get the lay of the land. Getting a job as a pilot means someone else is paying for fuel and training. The main advantage of a fabric aircraft is the ease of repairs. If you end up going to a lot of off airport stuff you will start doing damage to the plane. Putting a patch on a fabric plane is a 1-3 hour job (mostly waiting for paint to dry). Damage a metal plane and you are talking real money.
DENNY
G44 wrote:Hammer, that was perfectly stated!
