mtv wrote:Also, a friend got field approvals to remove the fuel pumps on a number of Avcon converted 170 and 172s. He did so by replacing the fuel line between the fuel selector and the gascolator with a larger diameter line. The original line was too small to reliably flow max fuel for an O-360 in all attitudes. Pretty simple way to get rid of two pumps and some weight.
If you could share a name or more details- private message if you like, that would be great!
IMO, the old line was big enough, the agitation the pumps added to the system was the culprit in the very brief Peterson test. The hot fuel on a hot day, running through two pumps, it caused the easily vaporized components to flash. Get rid of the pumps, the fuel isn't disturbed, and it stays a liquid. That said, if going to a bigger line makes everyone happy, that is a small price to pay, I'll stand in line in order to get rid of two pumps that only add weight and likely decrease safety. (if you want to understand the problem better, do some reading on fuel distillation curves).
And, an observation for those concerned about running mogas in a 8.5 to 1 compression O-360. The engines run fine when in a Cherokee (STC available), and now, put them in a Cessna, and somehow it will damage the engine?
