Over the past three decades, or so, I have heard of cessna fuel bladders being sucked up to the filler cap. But since the invention of new style vented fuel caps, I haven’t heard of this much. Imagine my surprise when I returned from a three hour flight and tried to refuel my right tank and found my bladder staring at me in the filler neck.
We have an older 182L (68’) with long range tanks. We put the Monarch fuel caps on the plane when we bought it back in 2006. We also replaced both bladders in 06’ and 07’. Through the years we struggled with the common problems having to do with the Monarch caps; bad O-rings, cap bottoming out on the tab in the filler neck, venting fuel out the top of the wing ect. But that was all in the early days.
For the last few years everything had settled down and we really haven’t had any fuel issues until about six months ago when our R/H FFC bladder started to leak when more than 30 gallons was put in. This was right in time for our annual. At annual we traced the tell-tell blue stains and determined that our leak was in fact emanating from the bladder and not a loose clamp or nipple. So we pulled the bladder out and found the hole located where the tank would rest up ageist the rear spar. A few days later we installed a new bladder, hoses, clamps drains, and removed and retapped the entire bay. Filler er’ up and no leaks so good to go. Since the annual, we have put around 35 hours on the plane with no evens but the oil change.
Needless to say I am a little mystified with the situation. I have changed half a dozen cessna bladders through the years and and am at a loss for how this might have happened. Tomorrow I will be able to de-fuel the plane and start looking/fixing the situation. To my mind, I would have to of had two separate issues. The first would be a plugged check valve or vent line under the left wing (old Cessna so only one vent). The second would be a defective diaphragm in my R/H gas cap.
Looking for anyone who may have had a similar situation and what you found. Also any other imput or advise is welcome. Thanks!
