jaudette wrote:You'll save a lot of weight moving that battery. Selkirk is an inexpensive option and looks great!
Jim
mtv wrote:Where's your ELT? Because of the later guidance requiring VERY solid mounting of the ELT, I chose to cut a hole in my extended baggage, put a hinged door on it, and mount the ELT under that, running reinforcements front to back between ribs to stiffen the mounting. Worked great, got the ELT out of the way, VERY solidly mounted, and well protected from stuff in the aft baggage.
Seems you could do the same with that hole for the battery that you've already moved.
albravo wrote:With my 182F I decided the extended baggage just wasn't worth it. I have the battery, the ELT and the pump for my amphib gear in there and by the time I work around it there won't be any room for stuff.
I was also advised against the firewall battery because of the tendency to be nose heavy.
Sure like seeing those photos of the pimped out 182s. Gorgeous.
