Hey guys,
Relatively new 1963 182F owner looking for some help. Plane is bone stock. I understand that the early 182's have a smaller elevator, and my empty CG is 34.1" @ 1745.... which based on my research is further forward than most. I'm all out of trim on final and really would like more elevator authority during flare.
What sort of options do I have for making my plane more balanced? Extreme changes like lighter hardware on the front end are not in the budget right now....
My IA offered to add some weight in the empennage to bring the CG back, adding weight isn't my first choice, but at least it'd be less weight by going that far back. What's a good empty CG to target? I'm seeing a lot of 36-37" planes around, but they're often heavier than mine.
Is it possible to modify the elevator, such as with VG's to increase low speed authority? Can one install VG's on just the elevator without doing the entire plane?
Thanks!
