Below is a link to a previous discussion.RockHopper wrote:My opinion as someone who has had both (and we know what opinions are worth). I have an A185F with a Pponk built IO-550D. There is NO comparison between the 550 and the 520. Cubic inches to begin with. On top of that, the two engines are rated using different engineering criteria. If I remember correctly, the 520 was rated SAE gross which was on the dyno with no accessories (not sure if that included mags or not) 300 at 2850rpm with a 5 min limitation. 285 continuous. (A TCM rep I talked to said more like 270hp average)The 550 was flat rated under a net rating that required it fully dressed with all accessories and as you would find it as installed on an airframe. Under this rating the engine must make the rated 300HP plus 10% at 2700rpm with no time limit. You can pull that power all day long if you want to put 30 gallons an hour through it.The 550 had teething problems in the beginning. Soft cranks and cylinder ring step wear issues. That is pretty much all in the past. I'm sure someone will correct me on the rating details. It's been awhile since I have read the charts, so details are a bit fuzzy.
https://backcountrypilot.org/forum/engi ... o-550-2571
hotrod180 wrote:An American maxim: if big is good, bigger is better , and too much is best.
scottnt wrote:I upgraded to a 550 about 5 years ago. At max cruise it only made about a 6 knot difference, but in the middle of the power band the difference was significant. Whereas I used to cruise at 160 knots burning roughly 13 gph, now I can cruise at 174 knots burning about 14 gph. This is in a V-tail Bonanza. Climb performance was dramatically improved, and service ceiling has increased from about 18,000 feet up to 23,000 feet. It's a great engine.
