Backcountry Pilot • 2nd Happiest Day
2nd Happiest Day
27 postsPage 1 of 21, 2
2nd Happiest Day
According to legend the two happiest days of airplane ownership are the day you buy and the day you sell.
I'm going to have to assume the happier of the two is when you unload the derelict onto it's new money source, and that this day is merely the other day.
I've picked up a 150hp no-flaps Citabria (7ECA brought to 7GCAA trim) and managed to locate a hangar at Tacoma Narrows (KTIW) and got insurance through Avemco. I've got a few hours in this plane and another 65 or so in a different 7GCAA back when I was instructing - plus more recent time in a BT-13.
Hopefully picking it up tomorrow and bringing it home.
Then the burning of the Avgas begins.
I'm hoping to get a couple of years out of the covering and spars, but they've both been priced in so it's not like I'm naïve and hoping that all that is fine.
I plan on a metal belly but any other changes will be focused on reducing empty weight.
I know it's not a Super Cub and it's not a Maule. Or a Scout. But it's a tail dragger and it doesn't exactly suck at what it does.
aftCG offline
Aircraft: Kitfox series 5
Re: 2nd Happiest Day
Not any of those planes true....but you can get upside down and that's just as fun!
fiftynineSC offline
Aircraft: Cessna 185F
Very cool!!
I keep my '48 C170 at KTIW, so will keep an eye out for you!
48RagwingPilot offline
Great looking taildragger, and great pic's! If you wander to the dry side of the state, give me a holler!
Wa180 offline
FindMeSpot URL: https://us0-share.inreach.garmin.com/Fattyreflyer
Aircraft: SkyWagon 180E
SkyHawk 172K
Most excellent!
Opening the hanger to see your new plane just waiting for adventure, glorious.
Chazdevil offline
What airport were those photos taken at?
Thanks for the replies everyone. 48Ragwing, I'll look for you. My hangar is C9 over near the helicopter parts place.
Hotrod180, those pics were taken at Eatonville (Swanson). Base of the foothills Southeast of Puyallup.
This obscenely large chunk of blacktop is the ramp at TIW, where I learned to fly 20 years ago:
It was not actually great flying weather today
Poser shot.
Tucked away:
aftCG offline
AFTCG
Don't worry too much about what it isn't.
Just gives you other skills and judgments to learn along the way. :shock:
My first flight lessons in Idaho were done in a 115 hp. 7ECA.
Got it in and out of enough places to make me happy at the time.
A little unique local strip knowledge shared with a bit of show and tell helps. :D
Take yer time- take it easy - enjoy and have fun.
BUT- be safe
Chris C
wannabe offline
53 C-170-B+
Congrats! Great looking plane! I'm looking forward to reading about your adventures.
hawaiisurfer offline
It's an airplane, and it flies. Nothing to be ashamed of there. Have fun! Congrats!
Well the first thing I used the plane for was to fly to eastern Washington to visit my uncle. I left last Friday afternoon at 4pm from Tacoma and made about as close to a straight line as I've made, departing east just under the 1800' floor of a piece of Class Bravo airspace and then up through Stampede Pass and afterwards on a course that skirted south of Wenatchee.
Mt Stuart if I'm not my map reading skills aren't suffering too badly. It wasn't a bad ride at all if you're used to flying but I wouldn't have suggested it for a first passenger experience.
Near Quincy I dropped down to around 1500' AGL, pulled the power way back and followed the meandering aqueduct towards Ephrata where I made a rather stiff landing and parked the plane. My uncle was waiting for me, having followed my trail from my DeLorme InReach. We pushed the plane into the big hangar where his plane is stored, and then did a minor adjustment on the external power receptacle door. He had started to remove a small fairing in order to access the back of the quarter turn on the receptacle door but had one fastener that seemed like it had spun.
All of the other fasteners on the shroud went into nut plates. When I backed the screw out all the way I heard a nut roll somewhere inside the wing/fuselage joint. Not the sound I wanted to hear. We agreed that I would take a look from the front cockpit and see how bad the access was. Well after a few moments of looking I saw the hole easily - it was just straight down under the floor boards as far as I could reach if I my feet were just sticking above the canopy rail. So down I went. I retrieved the old nut and replaced it with a fresh one and held it with a wrench while he spun the screw from under the wing. Turns out that access to the back of the quarter turn was also in my face, so we remedied that as well.
The next day we pulled it out for the first time this year and went flying.
The picture above is from last year. I think I only took one picture of it this past weekend and it's not reachable from this keyboard.
In this case we put in about 1.7 hours doing a short cross country to Odessa to look at a Higher Power hangar door. Dood. Nice equipment. My uncle had the door code to his friend's hangar so he stayed in the back of the plane while I jumped out and hit the keypad. Inside was an AT802 (I think). What a beast. I laughed at the amount of bugs on the leading edges of the wings on the AT802.
I'm still getting used to flying the BT and Odessa might be the smallest runway I've dropped into. It's not that it's hard to fly, but it is heavier than most things I've flown which means when the sink rate starts getting uncomfortable you need to fix it quick. But the R-985 doesn't thrive on having the throttle tugged back and forth. Once I was established on final I was able to release some of the crease in the seat cushion and enjoy the, well, three point chirp and a low bounce. Dammit.
We took the long way home and did some sight seeing of the scab lands and little lakes. We examined some of his friend's homes from low level, prop forward of course. Got some waves. Pretty sure they were waves. Came up to pattern altitude 5 miles out and landed uneventfully. My logbook notes no fatalities.
Spent 20 minutes with a pressure washer getting the bugs off the leading edge of the wings. Another 10 or so dedicated to bird crap (top) and oil (belly) and then we used a tug to push it back for next time.
A quick lunch and I climbed back in the Citabria. Blasted off and put some effort into climbing above a scattered layer in hopes of a smooth ride. Climbing is something the 150hp Citabria does well. The problem with the smooth air on top was that it was a fairly significant headwind too. It was my intention to throttle back and do some cruising but this time it appeared I wasted my time climbing. So I dorked around for a while with power settings.
A user on this forum reached out to me recently who has quite a bit of time in my airplane and he was a gold mine of information. One of the power settings he said he liked was using 2200 rpm for about 90mph, and leaned appropriately (I'm fortunate that this plane has 4 channel EGT and CHT readings, plus digital oil temp and pressure).
Using the techniques mentioned in Positive Flying I started with the 2200 rpm setting I was showing 90-95 (statute) mph indicated. Correcting for TAS I would say it was just touching 95. From there I was able to reliably produce a 500 ft/min descent with 2000 rpm (indicating 95-100) and a 500 ft/min climb with 2400 rpm at 80mph indicated (spinner bump on the cowl just touching horizon) with zero trim corrections.
With three power settings to use for damn near every phase of cruise flight using zero trim changes makes for a pretty low workload. Of course there is still full power available when climb performance is critical, and of course "rental power" for when you just absolutely have to get there with less gas in the tanks. Using the same 2400 rpm setting for climb, but this time using a trim change I was seeing 115 indicated. Firewalled it will run right through 120 and into the yellow arc. The air wasn't smooth enough for yellow arc speeds and I'm actually paying for this gas and engine wear myself, so I don't mind pulling back the loud handle quite as much as I used to.
I kept wringing those numbers out and testing them until I ended up at 6500' just west of Thorp where I looked for the place where the powerlines go through Stampede Pass. I made a nice long descent to sneak under the class B rug again and called up my home airport. I was instructed to enter a 2 mile right base for 35. Pretty sure nothing fell off the plane on landing.
I went out the next morning and did five laps of the pattern in .7 hours. My patterns were nice and tight, my altitude control was good and I finally made five decent landings in a row. Smile on my face the whole time.
aftCG offline
Beautiful airplane and nice shots! I've loved every airplane I've owned, each one had it's own forte. Congratulations on your new bird!
scottnt offline
Beautiful plane and great pics! :D
Mountain Doctor offline
Aircraft: Maule MXT-7 180A
Nice airplane. I owned a 7ECA many moons ago when I lived in bush Alaska and it was a great little airplane. Flew it around quite heavy most of the time and she still did a good job, even with 2800 hrs on the little O-235-C1.
I had 8.50's on mine, VGs works really well with that wing. Plus you're way more comfortable in a Citabria than a little bitty cub, and for me it's better than a Maule too!
Enjoy the heck out of it!
akaviator offline
Aircraft: Cessna 180
Congrats, nice plane! I'm still working on my TW endorsement in a 7KCAB. Such a simple little plane, yet really fun to fly. I could see owning one some day.
colopilot offline
Aircraft: 57 182A
I've flown 3 iterations of that airplane, a Super Decathlon (180hp, CS prop) painted just like your airplane, a red and white 150hp Decathlon, and a bright yellow 150hp Citabria. The two Decathlons were when I was taking aerobatics lessons at Boulder back in 1980-81, and the yellow Citabria was about 14 years ago when I decided I should get semi-competent in a tailwheel again. My instructor in the yellow one had cleared me to solo it after 3 lessons, but before I could do that, some other nitwit groundlooped it on about the 3rd bounce and totaled it--very disappointed, because it was a fun little airplane, updated with the aluminum spar and some other nice doodads.
I guess what all that told me was that even I could fly a tailwheel because Champs are pretty easy airplanes, but it's still possible to get ham-handed (or footed) enough to screw up and damage things. So be careful, and enjoy your airplane!
About a year ago, I bought your airplanes older brother - a '65 7ECA, but mine still has the original O-200 engine. This plane is a sweetheart, and a TON of fun to fly.
I do kind of envy your rate of climb, since mine doesn't climb very fast (350 fpm at gross weight on a 100ºF day at 600 ft MSL). But it makes up for the poor climb rate with a slow cruise speed (95 mph at 75% power), LOL.
But is sure is cheap when it comes to fuel burn – only about 5.6 gph at 75% cruise, and maybe 4-4.5 in the pattern. If I slow down to 80 mph, it's only burning a little over 4 gph, so I can cruise with the J3s, and fly well over 9 hours (39 gallon tanks).
I'm building a Bearhawk Patrol at home, and this plane is keeping me current. I'm actually flying it more than the much faster, fancier airplane I used to own... It's just pure flying fun. I learned yesterday that my Turn & Bank indicator has been inop since I bought the plane. It was only a blown fuse, but I realized that I spent ZERO time looking at the T&B since I bought the plane. I guess that's a "good thing" for a low-and-slow airplane, right? LOL
JP256 offline
Aircraft: Rans S-6ES
My plane is also a 1965. Serial number 290
aftCG offline
My serial number is 243. Probably only a few weeks between their "birthdays"...
JP256 offline
