Yeah, many of the Bearhawk 4-place and Patrol (2-place) builders swear by the Hartzell Trailblazer. Others prefer the simplicity of fixed-pitch props and go with Catto. A few have used ground-adjustable props, so they can optimize for the planned mission.
I can't find the reference now, but I saw a table showing static pull testing that was done on a Bearhawk comparing the Trailblazer, an MT (2-blade), one of the new Whirlwind composite constant-speed props, and a Catto fixed-pitch prop. The Trailblazer produced the most static pull. The surprize to me was that the MT came in last, as both the Whirlwind and Catto props out-pulled the MT.
The Hartzell Trailblazer was far and away the most expensive prop tested, but placed first in static pull. The next most expensive prop was the MT, which placed dead last in the static pull test. The CS Whirlwind composite prop placed in between the other two, but cost a good bit less than either Hartzell or MT. The biggest surprize to me was that the Catto prop, which cost about 1/4 as much as the Trailblazer, basically tied the Whirlwind's static pull numbers, and cleanly beat the MT's numbers.
Of course, there's no guarantee that "static pull" results translate directly into "real-world" performance, but it seems reasonable to expect it would translate at least into initial takeoff roll acceleration and climb performance. The Catto's performance has me seriously thinking about going fixed-pitch for my 180-hp Patrol...
