Zzz wrote:What's your empty CG value (moment) Jeff? If you compare it to other 170s and it's nearly the same, I would check the control unit between the headset ear cups; it may not have been fully programmed for taildraggers.
One trick I like is to overtrim for wheel or 3-point. I'll dial in more nose down for wheelies and more nose up for 3-point. Make you hold a little control pressure into the flare but then the control forces seem right for the attitude.
Well, Zane, I guarantee I'm not as good at this as you are. That's one reason I've tried to get the two of us together at different times as I plan to trick you out of some of your knowledge. I'd like to put you in my plane and fly for you and then let you pick me apart.
Fact is, I can wheel land the 170 all the way to a stop. My complaint is that my Stinson requires tons less forward yoke to do the same thing; its just much easier to do with far less forward pressure. This has led me to believe that there is an aft-heavy CG. I have not verified that. The books for that plane are not in front of me right now so I'll have to look it up later.
Even if the STC requires the battery to be in the back, maybe I will be able to improve my perceived balance issue with just a light battery. My preference though would be to have it on the firewall if I can. Where it is now precludes ever doing an extended baggage mod.
Lastly, I do trim in favor of which ever landing style I'm planning. But that is just the sort of not-in-the-books tip I hope to gain by flying with you one of these days.
As to the control unit between the ear cups: you know it need a software update
