Caution, lotsa soda, coffee and time on my hands...
First)....
Mission mission mission...
A lighter airplane may or may not mean squat to you... It's a pretty high priority for me, but within reason... My airplane weighs about 100#- 150# more than it could, but for my mission profile the few things I'd have to lose don't justify the compromise. For example, because I hangar it, I chose an RSTOL plane over a cuffed long wing. RSTOL weighs...But it still fits in any hangar...Also, I had a bare / polished plane, but ended up painting it as a result of the sand erosion it sees when I taxi past it every day in a Thrush... If I really need to cut that last 100' off my roll, I'll make two trips or fly the cub.
Second)
you guys can't have it both ways...
In other words you can't tell about all the refinements and additions Cessna made over the years, and then not agree that the 'wagons didn't gain weight, right from day 1.
I have seen the original W&B reports from a half dozen '53 models, and they all weighed between 1415 and 1550. Mine was 1466. These are not 'averaged paper weights' like we frequently see, the early 180s were all weighed and hand written up. And yes, it's true, virtually everyone of these planes gained weight as the years went by. Having said that, a simple return to that stock configuration should return you within pounds of that weight. R&R an old radio, generator, starter, etc and you will
lose weight! Now add in a few modern necessities, and coming out a wash is very easily doable.
Mine came with a vfr panel, and no paint save the stripes. R&R ing the heavy engine accesories in favor of modern lightweight components and a lighter prop, actually more than compensated for the Pponk... More power / less weight, now ther's a no brainerd
Some food for thought;
FWIW, after much deliberation I went ahead and painted mine. I weighed it before, and I weighed it after, the paint cost me 38#s
That $#!ttty 170 tail wheel steering assembly is almost a full pound lighter than the very next revision, almost two#s less than the last. You can verify that with Tailwheel Tom Anderson...
Although to be completely honest, I thought we were discussing bushworthy airplanes here, if you are relying on tailwheel steering rather than brakes to turn your airplane, your idea of bush and mine are far different. If mine were not a standard A/W cert, I would just pitch the t/w steering and all it's associated cables and jibberish... never the less, if you like t/w steering, it's true, the early 180 is not for you
The 7/8" stinger on the early 180s... no rocket science there... I never have understood why guys buy an early plane and then bolt that 3500# 1 1/8", C185 stinger on there? Surely not to loose weight
The straight main gear are a full 17#s lighter than the raked heavy gear. You can verify this with Tailwheel Tom Anderson, but wait! a set of Ti gear, and you will drop that much more again! think they are not bushworthy? when Clauses 185 got totalled, they were one of the few pieces they used on the new one!
I have a stock '58 baggage door, (you know, the one that doesn't exist on a '53) and all the associated bulkheads, doublers, hinges, latches, etc. I bought them before I painted it. Weighed it all right before we went to the paint booth, and decided I just couldn't get that weight back off of it anywhere else. Everyone else's 'refinement', nothing but dead weight to me... Anyone wanna make an offer on it?
Ever look at the top of an early 180 wings and not see cracks or patches? (if so, I want those wings!) That's because the top skins are thinner than the later years. For the sake of this conversation we can replace thinner with lighter... But yes they are maintenance hogs
But that's not all... Mike is right, there is 'lighter' all over... as I posted above, the flaps are truss ribbed, you can look down one end and see straight thru to the other... Solid ribs for the later years, you just can't take that weight off a later model, but it doesn't exist from the get go on a '53...
The slant tanks of the first 180s? ever feel how heavy rubber is? guess what? there's another 2#s a side. Don't believe it? Hartwig, FFC, Aerotech... they all have the shipping weights. Of course then you have less gas
That wonderful C170 visibility you get with an early 180... you get that because that panel that is too small to house any instruments is smaller (read;lighter)
Did someone say visibility? soooo you want to be with the 'in' crowd and have a "1 piece windshield"
news flash... they're all 1 piece
now go pick up one with the strap, and one that's strapless
Being cool just cost ya almost double the weight
I just can't make this shit up, LP Aero, Cee Bailey, Great Lakes... they all agree
The early round back seats, uber light. Ditch the gay skirt that wraps around the bottom and does nothing but sit there looking fat, strip the springs and old padding in favor of a ceconite web followed by modern
upholstery, and you will be 12-13#s... Mine are 13#s wrapped in leather with seat heaters installed. Try that with a fully articulating late model seat...
At the end of the day, Mike is again right.... more often than not, the guy with the early plane is doing his best to make a 185 out of it, and the guy with the heavy later plane is trying to drop a few pounds from it. Doesn't make much difference to me, except when someone calls BS on something I posted, I don't mind backing it up with a few plane old facts
Myths and wives tales??? I dunno, that might be the weekend warrior, who heard from a freind of a freind...
Me? I just wanted a 2 place 'bush beater' that will play in the sticks and still get my bride there in timely comfort... so far so good
Taj, give Dave Calkins in Anch a call, he is a no BS I/A that knows a few things about the early birds. He maintains a couple really, really nice '53's and I believe those planes come in at 1530#s +/- with big engines, long wings and bushweels. Also overlooks several real hot rods. Last I talked to him he was going with twin rayjays on his '53... not my cup of tea, but for someone in Colorado looking for an early bird it sounds like just the ticket
Oh, and FWIW, the '53 is not my favorite year, nor best fit for me... I can't stand the door latches
Take care, Rob
