dprathe wrote:While it is true the Landes/Airglas STC requires the same size tire at all three stations, I recently obtained a field approval from the Seattle FSDO for an 8.00 on the nose and 8.50's on the mains using the Landes/Airglas nose fork. The only condition imposed by the FAA was that I change from aluminum axles on the mains to HD steel axles, which I was going to do anyway. This setup was a change from 8.00's all around with the Landes/Airglas nose fork. If you're interested in a copy of the field approval, I'd be glad to send it, provided I can figure out how. BTW, I'm very happy with this setup and have notice no change in IAS.
When I purchased and installed the Landis kit on my 58 182 about 2-3 years ago, the STC requires an 850 on the nose and at least 850's on the mains.
You say the Landis kit you purchased, the STC requires 800's on all three points
